0 Replies Latest reply on Jul 22, 2009 2:07 PM by Paul Reilly
    [svn:fx-trunk] 8742: * Revert revisions 8682 and 8734 due to performance issues.
    Paul Reilly Level 1
      Revision: 8742
      Author:   preilly@adobe.com
      Date:     2009-07-22 14:07:24 -0700 (Wed, 22 Jul 2009)
      Log Message:
      • Revert revisions 8682 and 8734 due to performance issues.  I'll
        recommit when they are worked out.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      Bug unfixed: SDK-14251
      API Change: NO
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-14251
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/AbcCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Method.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Variable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/TypeAnalyzer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/As3Class.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Method.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/TypeTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Variable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
      Removed Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Assignable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/reflect/Assignable.java
