2 Replies Latest reply on Jul 23, 2009 4:29 AM by Roy Marshall
    [JS][CS3] Script Librarys
    Roy Marshall Level 1
      Hi.
      I am going to be embarking on a large scripting project soon, and would like to know if there is any way I can point a script to a different script file containing my commonly used functions.  This is something similar to (as my failing memory recalls) in c++, having the #include........ line at the top of the code.
      If this can be done, great, but if not, I can live with using simple functions in the one main script.
      Cheers
      Roy
        • 1. Re: [JS][CS3] Script Librarys
          Hi, Roy!
          Check the following file of the InDesign CS3 SDK:
          javascript_tools_guide_cs3.pdf
          p216 "Modular Programming Support"
          Excerpt:
          "ExtendScript provides support for a modular approach to scripting by allowing you to include one script in
          another as a resource, and allowing a script to export definitions that can be imported and used in another
          script."
          also see the following file of the InDesign CS4(!) SDK:
          ar42s03s03.html
          "Loading external scripts"
          Excerpts:
          "ExtendScript has an #include feature you can use to include an external JavaScript file, so the functions in the include file are available for the locale script to use; however, you cannot use it to load a compiled binary script. If you want to distribute your JavaScript feature in binary format like Export as XHTML, you cannot use #include to load an external JavaScript file."
          "In CS3, Export as XHTML’s source has a function called loadScript()"
          Greetings,
          Uwe
          • 2. Re: [JS][CS3] Script Librarys
            Hi Uwe.
            Thanks for that solution.
            That was really easy!!!! and I will use this feature to keep my common code in one place.
            Thanks again matey,
            Roy
