4 Replies Latest reply on Aug 29, 2011 6:44 PM by lrkirven
    getDefinitionByName() error when calling class between modules
    kerna1
      i have a main application which loads two modules - lets call them x and y.
      module x has a class called dataObject. i have made a dummy instance of this class in module x.
      in module y, i have the following code:
      flash.utils.getDefinitionByName( 'dataObject' )
      the main app loads both module x and y successfully in seperate child domains BEFORE calling the line above.
      i am getting a variable 'dataObject' is not defined error.
      i know the reason why this error occurs under normal single-app circumstances. however, i could not find any posts relating to this error when dealing with multiple modules loaded dynamically. i have tried loading both modules in the same domain as the main app but still no luck.
      any help appreciated!
      thanks!
