9 Replies Latest reply on Jul 23, 2009 10:27 PM by Roy Marshall
    [JS][CS3] Selection Menu with images
    Roy Marshall Level 1
      I have no idea it this is possible, but I have written this code at the start of a script to select a function within the script:
      myDialog = app.dialogs.add({name:"Catalogue Selector"});
      with(myDialog)
              with(dialogColumns.add())
                with(dialogRows.add())
                     staticTexts.add({staticLabel:"Select the required catalogue:"});
                     myOptionButtons = radiobuttonGroups.add();
                     with(myOptionButtons)
                          radiobuttonControls.add({staticLabel:"VW"});
                          radiobuttonControls.add({staticLabel:"Peugeot"});
                          radiobuttonControls.add({staticLabel:"MG Rover"});
                          radiobuttonControls.add({staticLabel:"BMW Special"});
                          radiobuttonControls.add({staticLabel:"Nissan HTML"});
                          radiobuttonControls.add({staticLabel:"Nissan XLS"});
                          radiobuttonControls.add({staticLabel:"BMW (GB)"});
                          radiobuttonControls.add({staticLabel:"SEAT"});
                          radiobuttonControls.add({staticLabel:"Citroen"});
                          radiobuttonControls.add({staticLabel:"Vauxhall"});
                          radiobuttonControls.add({staticLabel:"SAAB 1st Column"});
                          radiobuttonControls.add({staticLabel:"SAAB 2nd Column"});
                          radiobuttonControls.add({staticLabel:"Audi"});
                          radiobuttonControls.add({staticLabel:"Fiat"});
                          radiobuttonControls.add({staticLabel:"Ford"});
                          radiobuttonControls.add({staticLabel:"Ford LCV"});
                          radiobuttonControls.add({staticLabel:"Honda"});
                          radiobuttonControls.add({staticLabel:"Vauxhall FUNNY SIZE"});
                          radiobuttonControls.add({staticLabel:"Hyundai"});
      myResult = myDialog.show();
      and what I want to be able to do is add an image to each option.
      Is this possible?
      I am looking to work with CS3 only at the moment.
      Cheers
      Roy
        • 1. Re: [JS][CS3] Selection Menu with images
          sorry, please ignore the "&n bsp;"
          Not sure how that happened.
          Roy
          • 2. Re: [JS][CS3] Selection Menu with images
            Kasyan Servetsky Level 5
            You can do this using ScriptUI (not InDesign's dialog). ListItem has image property:
            An image object for an icon to display in the item.
            When specified, the image appropriate to the selections state is drawn to the  left of the text label.
            Kasyan
            • 3. Re: [JS][CS3] Selection Menu with images
              Thanks for the reply Kasyan
              I am building the dialog, (I am not sure I am using ScriptUI) as below:
              var myDialog = new Window('dialog', 'Roys Box');
              myDialog.frameLocation = [100,100];
              myDialog.size = [500, 120];
              myPanel= myDialog.add('panel', [10,10,480,100], 'Roys Panel');
              myTopText = myPanel.add('statictext', [17,15,100,55],'Top Text');
              myBottom = myPanel.add('statictext', [17,50,100,85],'Bottom Text');
              myLine= myDialog.add('panel', [18,55,370,0], 'Roys Panel');
              myOKButton = myPanel.add('button', [390,10,75,10], 'Done',{name:'ok'});
              myCancelButton = myPanel.add('button', [390,40,75,25], 'Cancel',{name:'cancel'});
              myImage = myDialog.add('image',undefined,"image.png");
              but the myImage line errors saying 'File or Folder does not exist'.  The guide does not state how to use this method including the file path.
              Any ideas on how to make this work?
              Cheers
              Roy
              • 4. Re: [JS][CS3] Selection Menu with images
                After playing with all ways of code, I got it!!!:
                myImage = myDialog.add('image',[490,30,588,95],'~/image.png');
                Phwew!
                Roy
                • 5. Re: [JS][CS3] Selection Menu with images
                  Adobe-InDesign CS4 Level 1
                  Dear  Roy Marshall
                       Stored in your "image.png" file in Local or Server Folder then please insert the Folder name in the line...
                  for Example :
                  myImage = myDialog.add('image',undefined,"c:\\Images\\image.png");
                  Thanks & Regards
                  T.R.Harihara SudhaN
                  • 6. Re: [JS][CS3] Selection Menu with images
                    Thanks for that.  I got there in the end.
                    One last thing (for now anyway) I have this bit of code:
                    //Adding Buttons
                    myButton1 = myPanel.add('button', [380,13,75,25], 'Choose',{name:'button1'});
                    myButton2 = myPanel.add('button', [380,53,75,25], 'Choose',{name:'button2'});
                    myButton3 = myPanel.add('button', [380,93,75,25], 'Choose',{name:'button3'});
                    myCancel = myDialog.add('button', [500,120,100,25], 'Cancel',{name:'cancel'});
                    myImage = myDialog.add('image',[487,16,588,100],'/Macintosh HD/Applications/Adobe InDesign CS3/Scripts/Scripts Panel/Images/xxx.png');
                    myCopyright = myDialog.add('statictext',[15,153,400,172],'©xxxxxxx Ltd 2009');
                    if (myResult == 'myButton1')
                         alert ("myButton1 was pressed");
                    if (myResult ==2)
                         alert ("Cancel was pressed");
                    I need to run a function depending of the myResult, but the above myResult bit isn't working at all.  Cancel does work, but not:
                    Can someone please give me the correct syntax for this?
                    Many Thanks
                    Roy
                    • 7. Re: [JS][CS3] Selection Menu with images
                      Dear Roy Marshall
                        Please use the below code:
                      var myDialog= new Window(''dialog','Sample');
                      //Adding Buttons
                      myButton1.onClick= function()
                          alert("this is First");
                      myButton2.onClick= function()
                          alert("this is Second Button");
                      myButton3.onClick= function()
                          alert("this is Third Button");
                      myCancel.onClick= function()
                          alert("Close the Menu");
                           myDialog.close();
                      myDialog.show();
                      Use this Code!!
                      Regards
                      T.R.Harihara SudhaN
                      • 8. Re: [JS][CS3] Selection Menu with images
                        Beautiful!!
                        Thanks alot mate.
                        Roy
                        • 9. Re: [JS][CS3] Selection Menu with images
                          var dlg = new Window('dialog', 'Alert Box Builder',[100,100,480,245]);
                          dlg.btnPnl = dlg.add('panel', [15,50,365,95], 'Test it');
                          dlg.btnPnl.testBtn = dlg.btnPnl.add('button', [15,15,115,35], 'Test');
                          dlg.btnPnl.buildBtn = dlg.btnPnl.add('button', [125,15,225,35],'Ok', {name:'ok'});
                          dlg.btnPnl.cancelBtn = dlg.btnPnl.add('button', [235,15,335,35],'Cancel', {name:'cancel'});
                          dlg.btnPnl.testBtn.onClick = function() {
                              // Test something
                              dlg.close(3);
                          myResult = dlg.show();
                          if (myResult == 1) {
                              alert ("Ok was pressed");
                          else if (myResult == 2) {
                          else if (myResult == 3) {
                              alert ("Test was pressed");
                          By default, OK button returns 1, Cancel -- 2, if you use additional buttons, set return parameter of close method to a number to be returned from the show() method that invoked this window as a modal  dialog.
