7 Replies Latest reply on Jul 25, 2009 11:59 AM by christoon_ca
    array loop problem
    christoon_ca
      Hi
      This is probably easily remidied, but my mind is a little over stuffed right now.
      How do I make this work?
      for (i=0; i<connVis.length; i++)
           if (connVis[i] == 1) {
                wireConnVar[this]._x += 130
           } else if (connVis[i] == 2) {
                wireConnVar[this]._x -= 130
      Any ideas are greatly appreciated.
        • 1. Re: array loop problem
          dalcde Level 1
          I'm not sure what you want to do. Can you explian it with words, or put the whole code?
          • 2. Re: array loop problem
            christoon_ca Level 1
            that would probably be a good idea...
            I want to find any variables in the connVis array that are equal to 1 or 2, and move their respective mc instances accordingly.
            so if:
            connVis[7] == 1
            then move
            wireConnVar[7] this amount
            and if:
            connVis[9] == 2
            then move
            wireConnVar[9] this other amount
            Does that make sense?
            • 3. Re: array loop problem
              dalcde Level 1
              That means connVis is an array, and wireConnVar is an array of objects. You can change the [this]s into [i]:
              for (i=0; i<connVis.length; i++){
                        wireConnVar[i]._x += 130
                        wireConnVar[i]._x -= 130
              I think adding the brackets are better, but I think they will work without them.
              • 4. Re: array loop problem
                Thanks for the reply dalcde.
                A couple of things, first: neither work for me. And secondly, when I looked at my email notification of your reply it read differently than it does on the forum page.
                did you mean for it to read like this (note the asterisks):
                          wireConnVar[*i*]._x += 130
                          wireConnVar[*i*]._x -= 130
                or this:
                Also, I forgot to add that this is happening on a button event...
                myButton.onRelease = function() {
                • 5. Re: array loop problem
                  dalcde Level 1
                  It doesn't matter if it is a button or not. This is the correct one:
                  The brackets for "for" is optional, as long as it just contain one thing ( e.g. if/while/for statements, one line code etc. )
                  • 6. Re: array loop problem
                    dalcde Level 1
                    It seems that tabs in quotes are longer than normal ones.
                    • 7. Re: array loop problem
                      So, on coming back to this I realized that:
                      1. You were right dalcde, the syntax was fine
                      2. I should post the whole code because then dalcde would have noticed my error immediately, which was that I was writing my array indices with names not their native numbers.
                      ie:
                      myArr = Array();
                      myArr[someName] = 0;
                      should be:
                      myArr = Array();
                      myArr[0] = 0;
