19 Replies Latest reply on Sep 30, 2008 5:39 PM by phrarod
    autosize new window?
    phrarod Level 1
      I'm working on a site where there are a lot photos that will go to the larger version when the thumbnail is clicked. Right now it just opens to a full-size browser window. Not very elegant. I don't have control over what size the client will eventually use in the larger photos when they do updates themselves.
      Is there a way to code it in css or just html where one the thumbnail is clicked on the new window with fit the size of the larger image exactly?
        • 1. Re: autosize new window?
          Level 7
          http://www.divahtml.com > DivaPOP
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "phrarod" <webforumsuser@macromedia.com> wrote in message
          news:gbmf2f$qcs$1@forums.macromedia.com...
          > larger
          > full-size
          > themselves.
          • 2. Re: autosize new window?
            Level 7
            You mean like this?
            http://www.doknowevil.net/litebox/
            --Nancy O.
            Alt-Web Design & Publishing
            www.alt-web.com
            larger
            full-size
            themselves.
            • 3. Re: autosize new window?
              phrarod Level 1
              As always - thanks Murray. I went through the FAQs for an answer as to whether when they say "popup" they don't mean something that a popup blocker on browsers will block do they? Nothing in the FAQs.
              • 4. Re: autosize new window?
                Level 7
                Yes, but popup blockers usually only block the popups that aren't triggered
                by a mouse click.
                news:gboh65$egc$1@forums.macromedia.com...
                • 5. Re: autosize new window?
                  Level 7
                  Murray never QUITE gets this - its divaPOPgold that handles images
                  rather than divaPOP.
                  The popups are *not* blocked by the standard popup blockers (which, as
                  Murray said, allow user-requested popup windows to open). Email me if
                  you have any questions, and here is a little example page:
                  http://209.200.94.134/divaPOPgold_demo.html
                  E. Michael Brandt
                  www.divahtml.com
                  www.divahtml.com/products/scripts_dreamweaver_extensions.php
                  Standards-compliant scripts and Dreamweaver Extensions
                  www.valleywebdesigns.com/vwd_Vdw.asp
                  JustSo PictureWindow
                  JustSo PhotoAlbum, et alia
                  • 6. Re: autosize new window?
                    Level 7
                    Heh - oops.
                    "E Michael Brandt" <michael@valleywebdesigns.com> wrote in message
                    news:gbotjr$t8k$1@forums.macromedia.com...
                    > Murray never QUITE gets this - its divaPOPgold that handles images rather
                    > than divaPOP.
                    > Murray said, allow user-requested popup windows to open). Email me if you
                    > E. Michael Brandt
                    > www.divahtml.com
                    • 7. Re: autosize new window?
                      phrarod Level 1
                      Thanks everyone - one of those should work fine. Appreciate it!
                      • 8. autosize new window?
                        phrarod Level 1
                        I've been trying to get lightbox to work. I like the look of it, but I'm not having luck.
                        I followed the instructions here: http://www.lokeshdhakar.com/projects/lightbox2/#support
                        http://www.alphareptile.com/delete.htm
                        • 9. Re: autosize new window?
                          Level 7
                          Just a quick look at your source code shows no reference to the three
                          litebox . js files needed to make this work.
                          1) Download .js file libraries and copy them to your local site folder.
                          Place them in a Scripts folder.
                          2) Insert HTML > Script Objects > Script > browse to the .js files. Do this
                          for each script.
                          3) Upload Scripts folder to your server.
                          --Nancy O.
                          www.alt-web.com
                          news:gbrpgo$pr0$1@forums.macromedia.com...
                          not
                          > having luck. I know I'm missing something simple. So after flailing around
                          for
                          > quite a while here's an example. The code is on the first image. I think
                          I'm
                          > not grasping the exact way to call out lightbox
                          > <a href="images/lucky.jpg" rel="lightbox" title="Featuredreptiles"><img
                          > class="cushycms" src="images/lucky.jpg" alt="reptile photo" width="160"
                          > height="120" /></a></div>
                          • 10. Re: autosize new window?
                            Level 7
                            Using Firebug in FF will help you alot. It would have shown javscript
                            errors as soon as that page loaded.
                            > not
                            > for
                            > I'm
                            • 11. Re: autosize new window?
                              phrarod Level 1
                              Hi Nancy. The files are there just not activated correctly. I'll follow your directions.
                              Thanks for the tip Murray, as always.
                              • 12. Re: autosize new window?
                                Level 7
                                You're welcome.
                                news:gbrugd$294$1@forums.macromedia.com...
                                > your directions.
                                • 13. Re: autosize new window?
                                  phrarod Level 1
                                  FF doesn't like the on load but I can't find anything that tells me why or what the error is. The onload has been in there for the PVII menus and validates ok. In fact no errors at all.
                                  Still can't get lightbox to work. I like the look of it, but I'm not having luck.
                                  • 14. Re: autosize new window?
                                    Level 7
                                    Builder is not defined
                                    [Break on this error]
                                    objBody.appendChild(Builder.node('div',{id:'overlay'}));
                                    lightbox.js (line 132)
                                    initLightbox is not defined
                                    [Break on this error] <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0
                                    Transitional//EN" " http://www.w3.or...
                                    delete.htm (line 1)
                                    $("overlay") has no properties
                                    [Break on this error] $('overlay').setStyle({ width: arrayPageSize[0] +
                                    'px', height: arrayPag...
                                    Firefox throws these errors.
                                    news:gbtmi7$dn2$1@forums.macromedia.com...
                                    > what
                                    > validates ok.
                                    > having
                                    > luck.
                                    • 15. Re: autosize new window?
                                      phrarod Level 1
                                      Murray you are not an ACE - you are a god. Ok, I found the error panel. Not sure what to do since some of these refer to the lightbox code itself. I'll keep prodding. Others get it to work, I should be able to.
                                      • 16. Re: autosize new window?
                                        Level 7
                                        Yeah - from the errors, it looks like your page is not finding the
                                        javascript files.
                                        news:gbtpke$hr4$1@forums.macromedia.com...
                                        > Not
                                        > I'll
                                        • 17. Re: autosize new window?
                                          phrarod Level 1
                                          I have the lightbox java files in a folder marked "js" which I dragged over from the download folder within Lightbox. Its in the main site folder not a subfolder/directory.
                                          I put this in the header:
                                          <script type="text/javascript" src="js/prototype.js"></script>
                                          <script type="text/javascript" src="js/scriptaculous.js?load=effects,builder"></script>
                                          <script type="text/javascript" src="js/lightbox.js"></script>
                                          I have the lightbox.css loading with PVII files:
                                          <body onload="P7_initPM(1,7,1,-20,10); initLightbox()">
                                          So would the scr="js/prototype...." be the problem as far as not finding the files?
                                          • 18. Re: autosize new window?
                                            Level 7
                                            Try browsing to the location where the page says the script can be found.
                                            news:gbtt8p$mgv$1@forums.macromedia.com...
                                            > a
                                            > the
                                            > files?
                                            • 19. autosize new window?
                                              phrarod Level 1
                                              Finally got it to work. Whew. The css file was either pointed incorrectly or it liked it all in one folder with subs(doubt it but I did it after finding another install instructions and re-pointed everything there.)
                                              Sweat!
                                              In case anyone reading this wants clearer instructions go here: http://zollinhofer.com/lightbox-faq#ainstall
                                              Thanks to all the kind people who responded to this thread.
