1 Reply Latest reply on Jul 24, 2009 5:34 AM by JeffryHouser
    check inside app if a .swc has been loaded
    kerna1
      hey,
      i have a class inside my app which needs to do two different things based on whether an external .swc file has been loaded. the .swc file has a library which i want to use only if it is present (loaded into the app). otherwise, i want to do something else.
      is there a nice way to check whether a library in the .swc is available (essentially, if the swc has been loaded) during runtime?
      thanks!
        • 1. Re: check inside app if a .swc has been loaded
          JeffryHouser Level 4
          I am confusd by your question.
          The Flex compiler optimizes an application--AKA swf--to remove all unused classes.
          If an instance of the class is instantiated in a Flex application, then that class goes into the final swf.  Even if that class is located in a swc library.
          You wouldn't be loading swcs individually in a Flex application.  As far as I know, there is no way to load swcs during runtime.
