7 Replies Latest reply on Jul 6, 2007 4:04 AM by MannenMytenLegenden
    How to create a new class
    MannenMytenLegenden
      I'm trying to create a new class called Questions, which has two properties (type and condition).
      The action script is saved in the folder myComponents under the project.
      When I compile the Main app, I get the following error message:
      "1172 Definition myComponents:Question could not be found."
      Why?
      How do you call a constructor for a new class, that is not an extension of an existing class?
      Regards
      /Acke
      //-----------Class----------//
      package myComponents
      // Import all classes in the mx.events package
      import mx.events.*;
      public class Question {
      // Public constructor.
      public var Question(){
      // Call the constructor in the superclass.
      //super();
      // Define properties and methods.
      // Define public vars.
      public var type:string;
      public var condition:string;
      //------Main----------//
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute"
      xmlns:MyComp="myComponents.*">
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.events.CloseEvent;
      import myComponents.Question;
      etc, etc....
        • 1. Re: How to create a new class
          Robert Hirst Level 1
          I think there is an error in your declaration of the construction. It's defined as a var, and it should be a function.
          should be
          public function Question(){
          • 2. Re: How to create a new class
            MannenMytenLegenden Level 1
            Thanks.
            But that gave the same error anyway.
            I will post an answer when/if I find one.
            Regards
            Acke
            • 3. Re: How to create a new class
              shawnoshawnuth
              quote:
              Originally posted by: MannenMytenLegenden
              Why?
              Regards
              /Acke
              import mx.events.*;
              //super();
              <mx:Script>
              <![CDATA[
              etc, etc....
              Here is a test class I created a while back, although this one does extend Object it might help you out a bit with your constructor issue:
              package com.evilest
              public class Testing_class extends Object
              private var message:String = new String();
              public function Testing_class(input:String) {
              this.message = input;
              public function showAlert():void {
              Alert.show(this.message, "sup");
              • 4. How to create a new class
                levancho Level 3
                if you are not doing anything in Question constructor you dont even need to define it , compiler will do it for you.
                so remove
                //super();
                it will work, but if you persist to have it there, change it to
                //super();
                also this code assumes that you main.mxml file is one directory up of you "myComponents" folder
                • 5. How to create a new class
                  Stupid me!!
                  I have two projects, Quest and AutoQuest, and I saved it under the wrong one!.
                  So, now it imports as it should.
                  Thanks everyone for your efforts.
                  Regards
                  Acke
                  • 6. Re: How to create a new class
                    Is the class in a file called Question.as?
                    • 7. Re: How to create a new class
                      Se my previous message.
                      Acke
