4 Replies Latest reply on Jun 29, 2007 9:30 PM by Newsgroup_User
    Duplicate Movie Clip Problem!!!
    Magiciandude Level 1
      Okay, here is my problem:
      When I added a duplicate movie clip script to my guy, he duplicates fine. But when he duplicates again it replaces the old duplicate!!! The main problem is that each NEW duplicate has a new name!!! I tested it with the namebox script at the end!
      onClipEvent(enterFrame){
      if(_root.randomtext >=.1 and _root.randomtext <=.15 and this._name=="frowny"){
      _root.i+=1
      duplicateMovieClip(_root.frowny, "frowny"+_root.i, this.getNextHighestDepth());
      if(this._name!="frowny"){
      _root.namebox=this._name;
      this._x-=10;
      Please help!!!
      Thanks!
      -Chris
        • 1. Re: Duplicate Movie Clip Problem!!!
          Anybody?
          Please?
          -Chris
          • 2. Re: Duplicate Movie Clip Problem!!!
            is that code attached to _root.frowny? and if the previous movieclips are being replaced it's because your depths aren't changing. but it just might be that the old movieclips are below the duplicated ones and not visible to you.
            • 3. Re: Duplicate Movie Clip Problem!!!
              Yes...the code is on the frowny movie clip.
              But the code says only to duplicate if his name is the original frowny. And every time it duplicates it sends it back to the original frowny's position and deletes the one thats already moved halfway across the screen!
              Also, why wouldn't the depth be changing? Is there a way to fix it if that IS the problem? I used this.getNextHighestDepth()) though...
              Well...thanks for your reply anyway!
              -Chris
              • 4. Re: Duplicate Movie Clip Problem!!!
                Level 7
                > at the end!
                > _root.i+=1
                > this._x-=10;
                > Please help!!!
                > Thanks!
                > -Chris
                Is this the effect you are going for?
                _root.i+=1
                var item = duplicateMovieClip(this, "frowny"+_root.i,
                this._parent.getNextHighestDepth());
                trace(item);
                this._x-=10;
