9 Replies Latest reply on Jul 29, 2009 6:57 AM by the_wine_snob
    adding title
    howardmil18
      Hi,,, I have just finished my movie and want to add a title. I would like to have the opening photo still as my TITLE and add animated
      "transparent" text to it. (meaning,,,the text will be translucent as you look at the still image opening my movie)
      What is the EASIEST way to accomplish this?
      thanks HOWARD
        • 1. Re: adding title
          the_wine_snob Level 9
          OK, to make sure that I understand what you want, let me restate what I think you want, and you correct me, if I am wrong.
          You want to do a Title "sequence" at the beginning of your movie. This Title sequence will be a still image (photograph), and the text will animage over it. The image will only be seen through the text, as it animates. If this is so, the easiest way will be to place the image on Video Track 1 (VT 1), and then create a traditional Title, and place it on VT 2. Note: use a heavy font, like Arial Black Bold. Keep the text limited. You want big, simple and bold.
          Use Keyframes Motion>Position to animate the Title on VT2.
          Add Track Matte Keying to the still Clip in VT 1, and link that to the Title in VT 2. Key to the Alpha of the Title on VT 2.
          That will allow the Title to "key" out everything, except where the text is.
          If I missed what you want, please correct me.
          Thank you and good luck,
          • 2. Re: adding title
            You could also use one of the Text Animations in the Titles workspace to animate your title.
            Otherwise, Hunt's advice to use two video tracks (in Timeline mode) is exactly what I would have recommended!
            • 3. Re: adding title
              Steve,
              Good tip. You can see that I think of life from a PrPro standpoint, and there are no Title Animations, other than straight Roll, or Crawl. I always think first of all animations being done with Keyframes.
              • 4. Re: adding title
                howardmil18 Level 1
                I think you got it, but I will wait to finish after I add a little more info. Then you can
                advise as to the previous detailed answer.
                The "Still Photo"  (from your excellent advise) beautifully opens up the film on VIDEO TRACK 2 as it fades into the movie
                in the first 4 seconds. THIS photo,,,I want to put some words on for my title as the video begins.
                Yes, the font should be transparent to see the backround of the Arizona sky.
                So, the picture is INDEED, on VIDEO track 2 .
                Now,,,,,,,,,lets put some TEXT on this opening STILL photo Sequence!
                Thanks, Howard
                • 5. Re: adding title
                  Take another look at our instructions, Howard.
                  The photo (background) goes on Video 1.
                  The TITLE goes on Video 2, above it on the timeline. (It's like layers, see?)
                  • 6. Re: adding title
                    Howard,
                    Steve is correct about the placement of the Title. I should be on a Video Track (VT) above the image. I used the example of the still being on VT1, and the Title being on VT2, as this would be the most common for an opening segment. If you want the text in the Title to be animated, say slide across the still image, that could be done with the animation Presets, or Keyframed. Keyframing, while requireing more work, also offeres much more control, and other Effects, added to the Title, can be Keyframed, as well.
                    If you do not want animation, you can place a Cross-Dissolve, or similar, onto the Head (and also Tail, if you want it) of the Title, to dissolve it in, and all of the background image out, with the exception of that area behind the text.
                    By default, the Black of the text in the Title will be transparent, to allow viewing of what is on the lower VT.
                    Here's a look at the Timeline:
                    Hope that this helps,
                    • 7. Re: adding title
                      howardmil18 Level 1
                               http://www.youtube.com/watch?v=pdk0u-Mz90
                      I also wonder why the original 720 by 480 which I finished in a 1280 by 720 HD 25 mpeg did not cover more of the picture box
                      what is the best way to finish a video like this for youtube
                      howard
                      I made the titles as you said but since the OPENING still was immediatley overlapping the beginning sequence,,,I added text
                      to the picture still and just kept it ON VIDEO 2 for a split second effect as you can see on the above youtube address.
                      Message was edited by: howardmil18
                      • 8. Re: adding title
                        howardmil18 Level 1
                        Sorry that the address is not correct. Lets try this again,,,,nope it doesnt seem to be taking
                        the LINK as I copy and paste it.
                        See what I did on youtube.  Look for: Gary Puckett and the Union Gap: By the Time I Get to Phoenix
                        so you can add to my previous questions
                        Howard
                        • 9. Re: adding title
                          Howard,
                          Can you post a screen-cap of your Timeline, showing the arrangement of the Clips?
