1 Reply Latest reply on Jul 26, 2009 11:51 AM by ShardulSingh
    project help
    sudarshan1413
      hello ... i have decided to use AIR+FLEX as for final year project (computer engg)..i will be developing a ERP module in flex for a company's one department and will be used by company in its intranet...
      i want to ask can i make the whole project in just one SWF file.....or should i make one SWF for each task and combine them.....or any other advice...
        • 1. Re: project help
          ShardulSingh Level 3
          Normally one swf is generated for an application.You should try to breakup up application in
          diffrenet modules if it is possible,then for each module a separate swf will be generated,
          which will be reduce the load of you application.Then according to your requirement you
          will load of unload a module means swf.But the main swf will always remain there.
          It is only related to the performance optimization otherwise you can use simply one
          swf as normally generated by a flex application.
          If you have any further querry pls feel free to ask.
          with Regards,
          Shardul Singh Bartwal
