3 Replies Latest reply on Jul 29, 2009 4:13 AM by Muppet Mark-QAl63s
    Get pasteboard items
    Peter Bossens Level 1
      How can I get the pasteboard items using Applescript in InDesign CS2?
      I want to inspect the properties of these items, and based on this, delete some of them.
      Peter
        • 1. Re: Get pasteboard items
          Muppet Mark-QAl63s Level 4
          Peter, Im new to both using ID and trying to script it so Im not sure what kind of milage you will get from this. This works for me with a very basic test document. The Idea being that page items that enter the bounds of a page have a parent class of 'page' where as page items that do NOT enter the bounds a page get a parent class of the 'spread' you will need to do some testing of your own.
          tell application "Adobe InDesign CS2"
          activate
          set PBI_List to {}
          tell document 1
          repeat with i from 1 to (count of spreads)
          tell spread i
          repeat with j from 1 to (count of page items)
          if class of parent of page item j as text = "spread" then
          set end of PBI_List to page item j
          end if
          end repeat
          end tell
          end repeat
          repeat with This_PBI in PBI_List
          select This_PBI
          delay 1
          delete This_PBI
          end repeat
          end tell
          end tell
          PBI_List
          • 2. Re: Get pasteboard items
            Mark,
            Perfect, this trick works perfect.
            And it also allows me to inspect certain properties of objects in the Pasteboard-list before deleting them.
            Thanks!
            Peter
            • 3. Re: Get pasteboard items
              Glad that it worked for you too. Only the second time i've looked inside the app's dictionary… Wow there's a lot in that i've got to learn!!!
