| Category | Description |
| RoboHelp | This is a general discussion area that should contain or topics that do not fit neatly into any other category. For example:
| RoboHelp for Word | This forum is for anything to do with using RoboHelp for Word up to the point where you start generating an output. Questions about generating outputs go into the appropriate output category. Please state clearly that you are using RoboHelp for Word to generate the output. |
| FlashHelp | Posts about the FlashHelp wizard and / or problems with the output. |
| Printed Documentation | Posts about the Printed Documentation wizard and / or problems with the output. |
| Source Control | Posts about using RoboSource Control or other source control products. |
| RoboEngine / RoboHelp Server | Posts about using RoboHelp Server or the earlier RoboEngine. Please include the version you are using. |
| Other Single Source Layouts | Posts about the wizard for any layout not listed here and / or problems with the output. |
| FrameMaker Integration | Posts about FrameMaker / RoboHelp integration. Questions about generating outputs after importing / linking go into the appropriate output category. Please state clearly that your source content was FrameMaker and which edition of the Technical Communication Suite you are using. |
| WinHelp | Posts about the WinHelp wizard and / or problems with the output. |
| WebHelp | Posts about the WebHelp wizard and / or problems with the output. |
| HTML Help | Posts about the HTML Help (CHM) wizard and / or problems with the output. |
| AIRHelp | Posts about the AIR Help wizard and / or problems with the output. |
| RoboHelp HTML | Anything to do with using RoboHelp HTML up to the point where you start generating an output. Questions about generating outputs go into the appropriate output category. |
| Multiscreen HTML5 | Anything that is specific to the HTML5 outputs introduced in RoboHelp 10 including the screen layouts and screen profiles. |
