1 Reply Latest reply on Jul 27, 2009 2:02 PM by Al Baker
    ColdFusion Won't Accept Network Solutions SSL Cert
    Al Baker Level 1
      I followed these instructions and it said "Certificate was added to keystore":
      Manually import a certificate
      1. Go to a page on the SSL server in question.
      2. Double-click the lock icon.
      3. Click the Details tab.
      4. Click Copy To File.
      5. Select the base64 option and save the file.
      6. Copy the CER file into C:\ColdFusion8\runtime\jre\lib\security (or whichever JRE ColdFusion is using).
      7. Run the following command in the same directory (keytool.exe is located in C:\CFusionMX7\runtime\jre\bin):
        keytool -import -keystore cacerts -alias giveUniqueName -file filename.cert
      from this url:
      Except the location was d:\jrun4\jre\lib\security.
      And this works: <cfhttp method="get" url="
      but this does not: <cfhttp method="get" url="https://www.missionlinen.com" />
      Why and how do I get the cert to work?
