0 Replies Latest reply on Jul 27, 2009 9:25 PM by bluethundr
    Flex installer will not acknowledge java home
    bluethundr
      I am running Debian Lenny. Java is installed and defined and on my root path.
      analytics:/home/bluethundr# echo $PATH
      /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/usr/lib/jvm/java-1.5.0-sun-1.5.0.17</code>
      No matter what I do no matter what JVM I install and put on the root path, the flex installer will simply not acknowledge it.
      analytics:/home/bluethundr# ./flexbuilder_linux_install_a4_081408.bin
      Preparing to install...
      Extracting the installation resources from the installer archive...
      Configuring the installer for this system's environment...
      No Java virtual machine could be found from your PATH
      environment variable.  You must install a VM prior to
      running this program
      Please help, I need to get flex for linux installed.
