3 Replies Latest reply on Aug 5, 2008 1:13 PM by bregent
    Frames do not align
    tgcom
      I have a frameset file with a fixed frame on top and variable frame on the bottom. The top frame has a table 900 pixels wide with a 900 pixel flash (swf) menu file in it. The bottom frame has a 900 pixel wide html frame. Both tables are centered in their respective frames, however they do not line up. The bottom frame seems to stay a little (3-5 pixels) left of the top frame. I tried flushing both left and that didn't work either. Any suggestions.
      tgcom
        • 1. Re: Frames do not align
          Level 7
          You will never be able to fix this. That's frames for you.... Consider
          what will happen when the bottom frame requires a scrollbar!
          Why are you using them?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "tgcom" <webforumsuser@macromedia.com> wrote in message
          news:g7a6hd$7nv$1@forums.macromedia.com...
          > (swf)
          > tables
          > tried
          > tgcom
          • 2. Re: Frames do not align
            tgcom Level 1
            I am using frames for simple navigation using the flash menu.
            • 3. Re: Frames do not align
              bregent Most Valuable Participant
              Simple goes out the window once you start using frames. Just make your site with flat pages. And reconsider using a Flash menu, at least until all search engines support them.
