8 Replies Latest reply on Jul 28, 2009 2:12 AM by ShardulSingh
    list item renderer override data method problem
    flx23
      Hi all ,
      i have a list and further a data renderer of it,,,when i visit the list component the item renderer override data method is executed first and later the init method of its parent component and due to which the data becomes null..and gives and error..init method should execute first..why its happening can any body tell me...here is my code
      item renderer code:-
      override public function set data(value:Object):void
                           super.data = value;
                           obj=value;
                          // change(value);
                          trace(data.FolderName.toString());  // gives error as data is null
        • 1. Re: list item renderer override data method problem
          Madhav Subedi Level 4
          even if data is null, you can use obj as it is assigned the same value.
          trace(obj.FolderName.toString());
          • 2. Re: list item renderer override data method problem
            flx23 Level 1
            @Madhav Subedi
            well how can i use obj..as its also null as the value that i am assigning to obj..dont u think it would also be null
            problem is the execution of code...first the parent component init method should execute not the override method of item renderer
            but i my case it doing opposite first override method is called then the init of parent component..how come that..
            • 3. Re: list item renderer override data method problem
              have you provided the constructor, and called super() method in it?
              • 4. Re: list item renderer override data method problem
                Virat Patel
                Hello
                Use like
                                     super.data = value;
                                    if(value != null)
                                         obj = value;
                                        // change(value);
                With Regards
                Virat Patel
                • 5. Re: list item renderer override data method problem
                  flx23 Level 1
                  Well guys my question is which method will be excuted first parent componets init method or the override method of item renderer...that is what i wana clear..in my case its item renderer's override method that executes first which results in a null DATA...
                  which is wrong the init method should execute first not the override...please clear me the question that's in bold
                  • 6. Re: list item renderer override data method problem
                    ShardulSingh Level 3
                    Surely the initialize of the parent is called first,then override of the itemrenderer.
                    You can check it from the code below.Pls let me know if u have any problem.
                    Main Application
                    <mx:Application
                    xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical">
                    <mx:Script>
                    <![CDATA[
                    import
                    import
                    [Bindable]
                    private
                    new
                    '1',color:'0xFF0000', names:'John'},
                    {seq:
                    '2',color:'0x00FF00', names:'Alex'},
                    {seq:
                    '3',color:'0x0000FF', names:'Peter'},
                    {seq:
                    '4',color:'0xFF0000', names:'Sam'},
                    {seq:
                    '5',color:'0x00FF00', names:'Alis'},
                    {seq:
                    6',color:'0x0000FF', names:'Robin'},
                    {seq:
                    '7',color:'0xFF0000', names:'Mark'}
                    private
                    var dataObj : Object = event.itemRenderer.data;
                    dataObj.color =
                    "0xFF00FF";
                    event.itemRenderer.data = dataObj;
                    private
                    </mx:Script>
                    <mx:VBox
                    width="300" height="100%"
                    horizontalAlign="
                    center" verticalAlign="middle">
                    <mx:List
                    id="listComponent" width="50%" height="100%"
                    borderStyle="
                    none"
                    itemRenderer="
                    listItemRenderer"
                    itemClick="onItemClick(event)" initialize="onInit()"
                    </mx:VBox>
                    </mx:Application>
                    listItemRenderer
                    <mx:HBox
                    xmlns:mx="http://www.adobe.com/2006/mxml" width="100" height="30" horizontalGap="5">
                    <mx:Script>
                    <![CDATA[
                    override
                    super.data = value;
                    </mx:Script>
                    <mx:Label
                    width="30" height="30" text="{data.seq}" />
                    <mx:TextInput
                    width="75" height="30"
                    text="
                    {data.names}" editable="false" color="{data.color}"/>
                    </mx:HBox>
                    Shartul Singh Bartwal
                    • 7. Re: list item renderer override data method problem
                      flx23 Level 1
                      @Shardul
                      Thanks shardul but in my case its doin the opposite..can u tell me where i am wrong ...
                      my item renderer code:-
                                           super.data = value;
                                           if(ListBase(owner).isItemSelected(value))
                                                  imgfolderMark.source=data.OpenFolderImg;
                                                  lblFolderName.x=30;
                                          else
                                              //if(data!=null)
                                                      imgfolderMark.source=data.CloseFolderImg;
                                                      lblFolderName.x=38;
                      parent component code
                      • 8. Re: list item renderer override data method problem
                        You have not provided the parent component code.I think initially your data provider is not having the data.
                        Pls check its lenght,I think it is being fill later.
                        with Regards,
                        Shardul Singh Bartwal
