3 Replies Latest reply on Jul 28, 2009 3:33 AM by Sean_Wilson
    Permanently changing the position of a sprite
    schaeffe
      I've used the set locv command to change the position of a puppeted sprite. It changes it just fine on the satge. However, when I stop the movie and rest to the first frame, the sprite jumps back to its original location on the stage. How do I make the change in position permanent?
        • 1. Re: Permanently changing the position of a sprite
          Sean_Wilson Adobe Community Professional
          You can select the sprite in the score/on the stage in the authoring environment, while the movie is stopped, and move it to where you'd like it, but I suspect you're asking for something different but aren't providing enough detail. You could use score recording (see 'beginRecording' in the help), or use the #beginSprite event to position a sprite before it's initially drawn.
          • 2. Re: Permanently changing the position of a sprite
            schaeffe Level 1
            Thanks for your quick reply. What I am doing is this: I have a script
            on a button. When I play the movie, the script moves a sprite on the
            stage to a certain location (using "set the locv of..." command). The
            sprite moves as expected. However, when I stop the movie and then
            "rewind" it, the moved sprite jumps back to its original location. I
            would like the location that the script moves it to to become its
            permanent location.
            • 3. Re: Permanently changing the position of a sprite
              I would like the location that the script moves it to to become its
              permanent location.
              So read the help around score recording, or "remember" where it finished and start it from there in the #beginSprite event
