1 Reply Latest reply on Jul 28, 2009 10:11 AM by Peter deHaan
    fx:XML differences compared to mx:XML
    Tariq Ahmed [ACP] Level 1
      I'm not sure if this is a bug or if behavior has changed.
      In Flex 3 if you had users.xml:
      <users>
        <user id="1">Joe</user>
        <user id="2">Jeff</user>
      </users>
      And did an:
      <mx:XML source="users.xml" id="usersXML"/>
      And traced usersXML.users.user.length() you'd get 2.
      In Flex 4, if you change it to:
      <fx:XML source="users.xml" id="usersXML"/>
      The same trace on usersXML.users.user.length(), returns 0. And if you dump the XML to a string, it shows correctly so the data is there.
      Bug?
      Thx.
        • 1. Re: fx:XML differences compared to mx:XML
          Peter deHaan Level 4
          I cannot repro this in 3.4.0.8798:
          Assuming the following XML file, users.xml:
          <users>
          </users>
          The following example displays 0:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
              <mx:Label text="{usersXML.users.user.length()}" />
          </mx:Application>
          And if I try the same code in Flex 4.0.0.8754, it also displays 0:
                  xmlns:s="library://ns.adobe.com/flex/spark">
              <fx:Declarations>
              </fx:Declarations>
              <s:SimpleText text="{usersXML.users.user.length()}" />
          </s:Application>
          Changing each example to display usersXML.user.length() correctly displays 0.
          Which version/build of the Flex 3 SDK are you using?
          Peter
