3 Replies Latest reply on Jul 29, 2009 12:42 AM by Virat Patel
    execute a command after 3 seconds...
    jonatasmz Level 1
      hey guys... there´s a way on AS to execute a command like.... menu2items.selectedIndex = 2; after some seconds?
      cya....
        • 1. Re: execute a command after 3 seconds...
          BennyBeta Level 4
          Yes, use a Timer.
          http://www.flexafterdark.com/docs/ActionScript-Timer
          Let me know if that helps...
          Ben Edwards
          • 2. Re: execute a command after 3 seconds...
            BennyBeta Level 4
            Example code:
            import flash.utils.Timer;
            import flash.events.TimerEvent;
            // create a timer that executes after 3 seconds, only once
            public var timer:Timer = new Timer( 3*1000, 1 );
            public function init():void
                 // add event listeners
                 timer.addEventListener( TimerEvent.TIMER, handleTimerEvent );
                 // start the timer
                 timer.start();
            public function handleTimerEvent( event:TimerEvent ):void
            Ben Edwards
            • 3. Re: execute a command after 3 seconds...
              Virat Patel
              Hello
              Check this code
                   private var intervalIndex : uint;
                   intervalIndex = setInterval(callAfterSomeTime,2000); // set function closure and interval
                   // setInterval method runs a function at a specified interval in milliseconds.
                   private function callAfterSomeTime():void
                        // do something
                        clearInterval(intervalIndex);
              may help you.
              With Regard
              Virat Patel
