Hi Rick,
No, I don't see that at all. I'm having several issues (quiz
problems), not sure what my work-around should be. For the Hot Spot
questions, it seems that if the user answers correctly, then during
"Review Quiz", it displays the message "you answered this
correctly", but there is no hot spot shown, displaying what the
correct spot was. If the user answers incorrectly, then during
"Review Quiz", it shows the spot(s) that was (incorrectly) chosen,
instead of showing the correct spot, and it doesn't even display
the message that they answered this incorrectly. I am considering
deleting the "Review Quiz" slide altogether, which would make my
Hot Spot problem OBE. It seems like a fine solution since they
already have a message telling them if it's correct or incorrect;
and for the incorrect, I branch to a slide showing them the correct
solution. So in essence, Review Quiz seems redundant and is only
causing me problems. At any rate, do you know of some setting that
I need to change so that the hot spot will show the correct answer
during Review Quiz? I didn't see anything.
Also, is there a good explanation somewhere of what the Quiz
Preferences -> Settings cause to happen during playback? (For
example, under "Required", and the five checkboxes at the bottom.)
I want my user to have 2 attempts at a question, but if they decide
to later jump back 25 slides & watch it again, I want them to
be able to have another 2 attempts (or at least one!), but the quiz
question is locked since they already took their 2 attempts the
first time through. I should mention that I am using Captivate 3
& publishing as a .exe, and the score is really meaningless,
it's just for them to see how well they know the material. I have
checked all 5 boxes at the bottom of the Settings, and for
"Required" I have tried both "User must take the quiz to continue"
and "Answer all - user must answer every question to continue." (I
confess, in testing, I haven't seen what the difference is between
these two.) Problem I'm having with both of these is the course
will lock up if they click on forward button or use progress bar to
get to the quiz question. Once at the question, it says "you did
not answer this completely", and clicking forward and using the
progress bar do not cause the course to continue, so it locks up.
My best guess to work around this issue is to try "optional - user
can skip this quiz" so that it won't lock up. If you have any other
ideas, I'd love to hear them.
I apologize I have 2 topics in here, but the quiz issues are
really annoying me, because I'm ready to deliver my first 3
lessons, except for these functionality problems. THANK YOU SO
MUCH!
