0 Replies Latest reply on Jul 28, 2009 10:35 AM by nlaurino
    Error using Acrobat Reader in W2K Terminsl Services
    nlaurino
      We are trying to install Reader 9.0 on a Windows 2003 SP2 64BIT Terminal Services server and have used several methods, but if anyone other thatn an administrator tries to open a PDF or start the program it receives a VB Runtime error and closes after acknowledging the error. The Application log shows: Faulting application AcroRd32.exe, version 9.0.0.332, faulting module msvcr80.dll, version 8.0.50727.3053, fault address 0x000046b4.
      I have installed it using the Add Remove Programs (which is suppose to put it in Install mode) and running it the first time as an admin while still in install mode. I also tried manually placing the server in install mode (change user /install) then running the app before putting it in execute mode, same result.
      Any information on getting this to work would be appriaciated.
      Nlaurino
