1 Reply Latest reply on Jul 29, 2009 7:01 AM by logeye
    I need help understanding how this works. AS 2.0
      Its my first time here and i only started learning flash today. I aint too great with maths and i was showed this piece of code that makes a triangles point follow the cursor. It involved mathimatical things ( which i aint so great at) and the guy said "You dont need to know how it works, just how to use it." well i copied his code and it worked, but i have no idea how to use it in other rotation apart from the one he taught us. I dont even understand how to redo his code i saved it to a word document and anytime i wanted to make something rotate something in that fashion i would refer to that. But i dont want to have to do that, i want to know how to use it, dont have to understand it, but use it for other rotation matters. If you are going to help, please try to be a bit simmple i explaining it, cause im new. Dont get me wrong i aint thick but i can find it a bit hard to follow some things, that is i my current problem.
      here is the rotation code:
      onEnterFrame = function()
      hero._rotation = getmouse(hero);
      getmouse = function(mc:MovieClip):Number
      dy = _ymouse-mc._y;
      dx = _xmouse-mc._x;
      rad = Math.atan2(dy,dx);
      rotate = rad*180/Math.PI
      return rotate+90
      also if it helps, here is the video i was watching: http://www.youtube.com/watch?v=w3OfrpbNhHs
      please if you can, explain how the entire thing works.
      thanks for any help given in advance.
        • 1. Re: I need help understanding how this works. AS 2.0
          Here's a short primer.  It may not be sufficient but here goes.
          1st, move the closing bracket at the end and put it on the third line.  This makes the code more efficient
          onEnterFrame = function(){                               // this causes Flash to repeatedly
        execute the next line at the
        frame rate you selected
        for your document
                 hero._rotation = getmouse(hero);               // this tells Flash to rotate a
        movie clip (named hero) based
        on the function getmouse()
          };        // putting the }; here makes the
        code more efficient and readable
          getmouse = function(mc:MovieClip):Number{   // This is the function called with
        mc referring to hero that was
        passed from the second line.
               dy = _ymouse-mc._y;                                // dy means delta y which subtracts
        the y position of the movieclip
        from the mouses y position
               dx = _xmouse-mc._x;                               // dx = delta x (same as above line
        but on the x axis)
        // once you have the x and y sides
        you male a triangle.
        Now use trig to find the angle
               rad = Math.atan2(dy,dx);                           // the computer works in radians
        the arc tangent atan2 will give the
        angle in radians
               rotate = rad*180/Math.PI                            // you want to convert the radians to
        degrees, that's what this line does
               return rotate+90                                         // this returns the value of rotate back
        to the calling function in line 2.
        the +90 determines which part
        // of the hero movie clip is facing the
          If you put the mouse cursor over any of the green reserved words above in the Actions panel you will get a desctription of what these do.
          hope that helps.
