0 Replies Latest reply on Jul 28, 2009 6:34 PM by Peter Farland
    [svn:fx-trunk] 8880: Removing hack of mapping FXG 2008 namespace to spark components.
    Peter Farland Level 3
      Revision: 8880
      Author:   pfarland@adobe.com
      Date:     2009-07-28 15:18:04 -0700 (Tue, 28 Jul 2009)
      Log Message:
      Removing hack of mapping FXG 2008 namespace to spark components. FXG can be used in Flex SDK 4 as either .fxg files (which are compiled down to SWF tags as an optimized static vector graphic), or converted to MXML 2009 + Spark mark-up (which represents graphics drawn usign ActionScript and editable at runtime).
      QE notes: No
      Doc notes: No
      Bugs: N/A
      Reviewer: For Joan to review
      Tests run: Checkintests Pass
      Is noteworthy for integration: Yes, /frameworks/fxg-manifest.xml is no longer packaged in the SDK and any custom /frameworks/flex-config.xml or /frameworks/air-config.xml files should remove references to fxg-manifest.xml.
      Modified Paths:
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/webapps/webtier/WEB-INF/flex/flex-config.xml
      Removed Paths:
          flex/sdk/trunk/frameworks/fxg-manifest.xml
