1 Reply Latest reply on Jul 29, 2009 4:55 AM by _Natasha_
    How to restrict firing multiple events from combobox
    SirajKhan
      Hi There,
      I am using a customized combobox which allows me to select multiple indices. It is working fairly okay, except that it is firing multiple "change" events on updating combobox selection; all I need is, when combobox selection state is updated, it should fire single change event.
      here's the code:
      package
          import flash.events.Event;
          import flash.events.KeyboardEvent;
          import mx.controls.ComboBox;
          import mx.events.FlexEvent;
          import mx.events.ListEvent;
          public class ComboBoxs extends ComboBox
              public function ComboBoxs()
                  super();
              private var ctrlKey:Boolean=false;
              override public function close(trigger:Event=null):void
                  if (!ctrlKey)
                      super.close(trigger);
              [Bindable("change")]
              public function get selectedIndices():Array
                  if (dropdown)
                      return dropdown.selectedIndices;
                  else
                      return null;
              public function set selectedIndices(value:Array):void
                  if (dropdown)
                      dropdown.selectedIndices=value;
              public function get selectedItems():Array
                  if (dropdown)
                      return dropdown.selectedItems;
                  else
                      return null;
              public function set selectedItems(value:Array):void
                  if (dropdown)
                      dropdown.selectedItems=value;
              override protected function keyDownHandler(event:KeyboardEvent):void
                  super.keyDownHandler(event);
                  ctrlKey=event.ctrlKey;
                  if (ctrlKey)
                      dropdown.allowMultipleSelection=true;
              override protected function keyUpHandler(event:KeyboardEvent):void
                  super.keyUpHandler(event);
                  if (!ctrlKey)
                      close();
                      var changeEvent:ListEvent=new ListEvent(ListEvent.CHANGE)
                      dispatchEvent(changeEvent);
      Thanks in advance,
      Siraj Khan
      khan_siraj@yahoo.com
