7 Replies Latest reply on Aug 4, 2009 1:34 PM by Gregory Lafrance
    CSS size text
    Jerry62712 Level 1
      I tried to set the width of a label using css and the "text-field-width" property that popped up from the Flex Builder.  But it didn't work.  What will work?
        • 1. Re: CSS size text
          Gregory Lafrance Level 6
          I don't think you can change the width of a label control in CSS in Flex.
          If this post answered your question or helped, please mark it as such.
          • 2. Re: CSS size text
            Jerry62712 Level 1
            I'm guessing you are right.  I wonder what that css property is there for if not to do that.  Do you know if it will work in Flex 4?
            • 3. Re: CSS size text
              joan_lafferty Adobe Employee
              Sorry Greg, this won't work in Flex 4 either. The width of a Label is controlled by the width property and not a style. Therefore, it won't be settable in CSS.
              Joan
              • 4. Re: CSS size text
                Jerry62712 Level 1
                I noticed that if I set "Text" in css, it is reflected in text fields and the size of the container adjusts.  If I then set the fontSize in ActionScript, I can get the size to change, but the container (a panel in this case) doesn't change causing a loss of data.
                1) How can I change "Text" in the css from ActionScript?
                2) Will this change the container to allow for the different sizes?
                3) How cqan I change the fontSize in ActionScript and have the container change?
                Here is a component of the mxml:
                <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml">
                <mx:Script>
                    <![CDATA[
                        [Bindable] public var noticeTitle:String;
                        [Bindable] public var noticeTop:String;
                        [Bindable] public var noticeList:String;
                        [Bindable] public var noticeBottom:String;
                </mx:Script>
                <!-- ** start of the notices area ************************************ -->
                    <mx:Panel id="noticeCompPanel"
                        cornerRadius="20"
                        backgroundColor="#d5d5d5"
                        borderColor="#000000"
                        x="5" y="0"
                        roundedBottomCorners="true"
                        headerHeight="16" width="655"
                        layout="vertical"
                        verticalScrollPolicy="off" horizontalScrollPolicy="off"
                        tabEnabled="true" tabIndex="310">
                        <mx:Text id="noticeCompTitle"
                            htmlText="{noticeTitle}"
                            fontSize="18"
                            paddingLeft="275"
                            width="100" />
                        <mx:Text id="noticeCompTop"
                            htmlText="{noticeTop}"
                            width="100%"
                            left="10" />
                        <mx:Text id="noticeCompList"
                            htmlText="{noticeList}"
                            leading=".5"
                            paddingRight="25"
                            width="100%" />
                        <mx:Text id="noticeCompBottom"
                            htmlText="{noticeBottom}"
                            width="90%"
                            paddingLeft="10" />
                    </mx:Panel>
                </mx:Canvas>
                • 5. Re: CSS size text
                  I'm not aware of a "Text" style in Flex, but if it exists you change it in AS with:
                  myComponent.setStyle("Text", "newValue")
                  with the double-quotes unnecessary for numeric values.
                  2) Will this change the container to allow for the different sizes? DONT KNOW
                  3) How can I change the fontSize in ActionScript and have the container change?
                  myComponent.setStyle("fontSize", 20)        but the container might not change.
                  • 6. Re: CSS size text
                    Jerry62712 Level 1
                    That resizing seems to be a problem. Sigh.
                    Text, like Button or Label are selectors in the Flex world.
                    • 7. Re: CSS size text
                      Oh, you mean ther Text component, then this should work:
                      <mx:Style>
                          Text {
                              fontSize: 20;
                      </mx:Style>
