9 Replies Latest reply on Jul 30, 2009 6:22 AM by kglad
    italic text from xml file to create dynamic menu
    wwscoper
      I have a working menu that pulls in data from an XML file. The movie clips are attached to the stage dynamically based on the number of XML items. I need most of the text formatted regularly, but one button requires some html formatted text. (italics). I've set the text box in Flash to html = true.
      Here is some of my code:
      tl["btn"+(i)].blackTxt.Txt.html = true;
      tl["btn"+(i)].whiteTxt.Txt.html = true;
      //Place the button name from names Array into the blackTxt text box
      tl["btn"+(i)].blackTxt.Txt.htmlText = (names[i]);
      //Place the button name from names Array into the whiteTxt text box
      tl["btn"+(i)].whiteTxt.Txt.htmlText = (names[i]);
      //XML
      <BUTTON LINK='http://www.website.com/'><![CDATA[text here <i>italics here</i> text here]]></BUTTON>
      When it shows up in Flash, I can see the <i> tags and none of the text is formatted in italics.
      Any ideas? Thanks for the help.
        • 1. Re: italic text from xml file to create dynamic menu
          use the firstChild.nodeValue to assign names
          • 2. Re: italic text from xml file to create dynamic menu
            wwscoper Level 1
            I may not have provided enough context. Here is more of the code:
            myXML.onLoad = function(){
            //Set varible to store the XML childNodes
            //This allows you to get the number of buttons in the XML file.
            //You'll use this tell flash how many times to loop the for loop.
            var linkname:Array = this.firstChild.childNodes;
            //Set a for loop
            for(i=0;i<linkname.length;i++){
            //Push the button name into the names Array
            if (linkname[i].attributes.NAME) {
            names.push(linkname[i].attributes.NAME);
            else {
            names.push(linkname[i]);
            //Push the button link into the links Array
            links.push(linkname[i].attributes.LINK);
            //Attach the button Movie Clip from the libray give it an instance name and place it on the next highest level
            tl.attachMovie("button","btn"+i,tl.getNextHighestDepth());
            //Set the y position of the buttons
            tl["btn"+i]._y = yPosition;
            //Increace the varible yPosition 15 pixel each time the loop runs to place each button under each other
            yPosition = yPosition + 18;
            //set text to html text
            //Assign the btnOver function to the button onRollOver state.
            tl["btn"+(i)].onRollOver = btnOver;
            //Assign the btnOut function to the button onRollOut state.
            tl["btn"+(i)].onRollOut = btnOut;
            //Assign the btnRelease function to the button onRelease state.
            tl["btn"+(i)].onRelease = btnRelease;
            //xml
            <NAVBAR>
               <BUTTON LINK='http://www.google.com'><![CDATA[text <i>italic text</i> text]]></BUTTON>
               <BUTTON NAME='button 1' LINK='http://www.google.com' />
            </NAVBAR>
            Thanks for the quick response.
            • 3. Re: italic text from xml file to create dynamic menu
              again, use firstChild.nodeValue:
              //Set a for loop
              else {
              names.push(linkname[i].firstChild.nodeValue);
              //xml
              <NAVBAR>
              </NAVBAR>
              • 4. Re: italic text from xml file to create dynamic menu
                wwscoper Level 1
                Thanks Kglad. I tried this but it doesn't seem to be working correctly. Everything between the "<i>the text between these tags is removed</i>" is removed from the string.
                • 5. Re: italic text from xml file to create dynamic menu
                  are you doing something that requires an embedded font and you're failing to embed italic font?
                  • 6. Re: italic text from xml file to create dynamic menu
                    wwscoper Level 1
                    Yes, I am embedding the font. I know I have the regular version of the font embedded. Is there any special trick to embedding two fonts for the same text box? I tried embedding the italic version too, but maybe I did something wrong.
                    • 7. Re: italic text from xml file to create dynamic menu
                      the easiest way to embed italic font is to create a textfield (offstage and/or not visible) and embed the font like normal and toggle the italic button.
                      • 8. Re: italic text from xml file to create dynamic menu
                        wwscoper Level 1
                        Thanks Kglad! The menu is working now with regular and italic fonts.
