0 Replies Latest reply on Jul 29, 2009 12:46 PM by Jason Szeto
    [svn:fx-3.x] 8906: http://bugs.adobe.com/jira/browse/ SDK-20758 - DropdownEvent. CLOSE event is not always dispatched when the dropdown is removed ( destroyed before closed)
    Jason Szeto Level 3
      Revision: 8906
      Author:   jszeto@adobe.com
      Date:     2009-07-29 12:45:46 -0700 (Wed, 29 Jul 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-20758 - DropdownEvent.CLOSE event is not always dispatched when the dropdown is removed (destroyed before closed)
      ComboBox was not dispatching a CLOSE event when the dropdown was closed due to a programmatic change while it was open. For example, if the dataProvider or a style was changed while the dropdown was open, we want to immediately close the dropdown.
      I modified destroyDropdown to always end the tween if one is currently playing and then close the dropdown with no animation. I added a new parameter to displayDropdown to open/close the dropdown without any animation. Where we were calling destroyDropdown(), I removed  the setting of _showingDropdown because that variable is managed in displayDropdown.
      Thanks to Brian Curtis for filing the bug and for the original patch submission.
      QE notes: Add tests for these use cases
      Doc notes: None
      Bugs: SDK-20758
      Reviewer: Alex
      Tests run: ComboBox
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/branches/3.x/frameworks/projects/framework/src/mx/controls/ComboBox.as
