1 Reply Latest reply on Jul 29, 2009 1:07 PM by Gregory Lafrance
    Could someone please run a small test?
    NewFlasherFromKS
      Hello out there,
      I am getting this compiler error where everything I have read says that what I do should be ok: My interest is to create a 'package level' variable - accessible from any class in the package.
      Could someone please perform the following 3 steps and report the results here?
      1) Paste the following code into a file Dummy.as located in a suitable directory - adapt the name components accordingly.
      package components {
          import flash.display.Sprite;
          var thingies:Array = new Array();          // this is the object of interest
          public class Dummy extends Sprite {}
      Your project should still compile - Dummy is not really used.
      2) In another component (which of course needs to be active in your project) add a variable like
           var dummy:Dummy;
      3) Does it still compile? That's the big question.
      When I do this I get the error message
           A file found in a source-path can not have more than one externally visible definition
                components:thingies;components:Dummy
      Bumm - show stopper.
      BTW the product is Flex Builder 3.0 build (3.0.2.214193)
      Thanks and best regards
      Helmut
