7 Replies Latest reply on Jul 29, 2009 10:49 PM by mahehasan
    how to make source path dynamic
    mahehasan
      hi,
      i'm new in flex.Here is my problem
      <mx:HorizontalList id="horizontalList" height="100" columnCount="6" dataProvider="{arr}">
      <mx:itemRenderer>
      <mx:Component>
      <mx:Image width="100" height="100" source="../../user/mahedi/weeding/album/{data}"/> /mx:Component>
      </mx:itemRenderer>
      </mx:HorizontalList>
      i want to make source path dynamic. i mean i collected userName and albumName from php and i could print in flex.But when i use in source like this this way source="../../user/{userName}/{albumName}/album/{data}" i fond error. how can i solve that please help me
        • 1. Re: how to make source path dynamic
          Madhav Subedi Level 4
          you need to fetch your dataprovider so that it not only contains the image source but the username and album name too....
          <images>
               <image>
                    <userName>user1</userName>
                    <albumName>album1</albumName>
                    <imageName>img1.jpg</imageName>
               </image>
               <image>
                    <userName>user2</userName>
                    <albumName>album2</albumName>
                    <imageName>img2.jpg</imageName>
               </image>
               <image>
                    <userName>user3</userName>
                    <albumName>album4</albumName>
                    <imageName>img4.jpg</imageName>
               </image>
          </images>
          <mx:itemRenderer>
          <mx:Component>
          <mx:Image width="100" height="100" source="../../user/{data.userName}/{data.albumName}/album/{data.imageName}"/>
          </mx:Component>
          </mx:itemRenderer>
          • 2. Re: how to make source path dynamic
            mahehasan Level 1
            Madhav Subed.Thank you very much for your reply.
            Actually userName and albumNam came from differen file. i mean when i load flex from php userName and albumName came at that time so when i want to show my pictur just i called the php which is like this:
            - <root>
            - <images>
            <image>1.jpg</image>
            <image>2.jpg</image>
            <image>3.jpg</image>
            <image>4.jpg</image>
            <image>5.jpg</image>
            </images>
            </root>
            and this data i saw with this
            <mx:HBox id="ShowTemplate"  horizontalCenter="0" y="537" borderStyle="solid"
                                    cornerRadius="10" borderColor="#F88B20" width="700"
                                    borderThickness="2" height="124" verticalAlign="middle" horizontalAlign="center">
                                <mx:itemRenderer>
                                    <mx:Component>
                                        <mx:Image id="kk" width="100" height="100" source="'../../user/Mahedi/weeding/album/{data}"/>
                                    </mx:Component>
                                </mx:itemRenderer>
            </mx:HBox>
            by called http service. When i use this source="../../user/Mahedi/weeding/album/{data}" there is no problem occur.
            but when i use this source="../../user/{userName}/{albumName}/album/{data}" the builder give me this type of message access of undifined property userName and same for other. I'm also used this
            source="{'../../user/' + username + '/' + albumName + '/album/' + data}"
            Have any solution.
            • 3. Re: how to make source path dynamic
              does it mean userName and albumName are the variables you already fetched in your application?
              if so, you need to access it through outerDocument, as they are not the part ( member ) of your itemRenderer component.
              source="../../user/{outerDocument.userName}/{outerDocument.albumName}/album/{data}"
              • 4. Re: how to make source path dynamic
                mahehasan Level 1
                Thank you very much.
                Yes you are right.
                When i use this path
                The builder give me like the attach doc(please see attach) file where i set the image
                please reply me.
                • 5. Re: how to make source path dynamic
                  mahehasan Level 1
                  Tank you very much.
                  May be file are not attached cause here occur some problem.
                  When i set the path
                  The builder give the message like this with yellow marker
                  Multiple markers at this line:
                  -data binding will not be able to detect assignments to userName
                  and other same message for naother variable
                  Please giude me
                  • 6. Re: how to make source path dynamic
                    declare those two variables BINDABLE in main file.
                    [Bindable] private var userName:String;
                    [Bindable] private var albumName:String;
                    • 7. Re: how to make source path dynamic
                      mahehasan Level 1
                      Madhav Subedi its great.Thank you very much.
