Under what settings does Captivate record the state change of various UI elements, like the depression of buttons and the checking of check boxes, as additional narrow, full-width bitmap slices which are not editable or localizable?
For new recordings, it looks like creation of these slices can be avoided by deselecting Record keystrokes in the Recording > Settings category in Edit > Preferences or in Record/Create > New Project > Settings. Is this correct and a known issue?
Has anyone any insight on how to avoid these uneditable full-width bitmap images? The goal is to have a single background that can be localized so they are a major headache and I'd like to know how they can be avoided. Thanks.
I'm complelely baffled. The only bitmap you should have is the background. If you haven't solved your problem, send me your file or a representative slide or two so I can take a look. Sounds like gremlins in the Print Screen key.
Leslie Bivens
E-Learning Developer/Captivate Coach
