0 Replies Latest reply on Jul 30, 2009 6:52 AM by andyulrika_is_back
    Panning sound in a flash member
    andyulrika_is_back Level 1
      Hello
      I have a flash member which includes an animated musical score with embedded audio track.
      I can stop, start and pause the flash score within director using lingo but am unsure how to use panning on the sound track. Is there a way I can control the panning of the sound that is embedded within flash?
      Any help much appreciated.
      Here is the code I currently use for controlling the stop, start and pause for the flash file.
      ----written for Director 8----
      ----Kumar.K----
      ----kumark@icode.com----
      ----Custom Properties----
      property
      FlashSprite,MyAction,WhereTo,Playafterrewind
      ----Get Behavior description----
      on
      getBehaviorDescription
      me
      return
      "Play/Pause/Stop/Rewind a Flash Sprite "
      & RETURN & RETURN &
      "This Behavior Play/Pause/Stop/Rewind a Flash Sprite."
      & RETURN & RETURN &
      "PARAMETERS"
      & RETURN &
      "* Flash Sprite"
      & RETURN &
      "* Action"
      & RETURN &
      "* Wheteher to Play/Stop after Rewind(use this if action is REWIND)"
      & RETURN &
      "* Where to assign this script"
      end
      ----Get Behavior Description List----
      on
      getPropertyDescriptionList
      me
      flashmememberlist = searchflashsprite(
      me
      propslist=[]
      if
      flashmememberlist.count() > 0 then
      SetaProp
      propslist, #FlashSprite, [#comment"Flash Sprite ",#format#integer,
      #range
      flashmememberlist,#default flashmememberlist[1
      else
      SetaProp
      propslist, #FlashSprite, [#comment"Flash Sprite ",#format#integer,#default 1
      end if
      SetaProp
      propslist, #MyAction, [#comment "Action " ,#format#String,#range["Play","Pause","Stop","Rewind"],
      #default
      "Play"
      SetaProp
      propslist, #Playafterrewind, [#comment"Play after Rewind(Use if Action is REWIND) ",
      #format#string
      ,#range["Yes","No"],#default "Yes"
      if the
      currentspritenum = 0
      then
      SetaProp
      propslist, #WhereTo, [#comment "Where To Attach ?" ,#format#String,
      #range
      ["On EnterFrame","On ExitFrame"],#default"On EnterFrame"
      else
      SetaProp
      #range
      ["On MouseUp","On MouseDown","On MouseEnter","On MouseLeave"],#default"On MouseUp"
      end if
      return
      propslist
      end
      ----Available for both Frame and Sprite Script----
      on
      isOKToAttach (me
      , aSpriteType, aSpriteNum)
      case
      aSpriteType
      of
      #graphic
      return true
      #script
      return true
      end case
      end
      isOKToAttach
      ----Check Whether Flash Member Availabale on the Stage----
      ----Events----
      on
      EnterFrame
      me
      if
      WhereTo = "On EnterFrame"
      then
      DoAction
      end if
      end
      EnterFrame
      on
      ExitFrame
      me
      if
      WhereTo = "On ExitFrame"
      then
      DoAction
      end if
      end
      ExitFrame
      on
      MouseUp
      if
      WhereTo = "On MouseUp"
      then
      DoAction
      end if
      end
      MouseUp
      on
      MouseDown
      if
      WhereTo = "On MouseDown"
      then
      DoAction
      end if
      end
      MouseDown
      on
      MouseEnter
      if
      WhereTo = "On MouseEnter"
      then
      DoAction
      end if
      end
      MouseEnter
      on
      MouseLeave
      if
      WhereTo = "On MouseLeave"
      then
      DoAction
      end if
      end
      MouseLeave
      ----Events----
      ----Search for Flash Member on the Stage----
      on
      searchflashsprite
      me
      set
      theflashmemlist = []
      repeat with
      i=1 to the
      lastchannel
      if
      sprite(i).member.type = #flash
      then
      theflashmemlist.
      append
      (i)
      end if
      end repeat
      return
      theflashmemlist
      end
      ----Custom Function to Perform the Action----
      on
      DoAction
      if
      member(sprite(Flashsprite).member).type=#flash
      then
      Case
      (MyAction)
      of
      "Play"
      if
      not sprite(Flashsprite).playing then
      Sprite
      (Flashsprite).Play
      end if
      "Pause"
      Sprite
      (Flashsprite).Hold
      "Stop"
      sprite
      (Flashsprite).frame=
      0
      Sprite
      (Flashsprite).Stop
      "Rewind"
      Sprite
      (Flashsprite).Rewind
      if
      Playafterrewind ="yes"
      then
      Sprite
      (flashsprite).Play
      else
      Sprite
      (flashsprite).stop
      end if
      End Case
      end if
      end
