0 Replies Latest reply on Jul 30, 2009 9:56 AM by Paul Reilly
    [svn:fx-trunk] 8934: * Reverted part of revision 4559 to get back compile time error
    Paul Reilly Level 1
      Revision: 8934
      Author:   preilly@adobe.com
      Date:     2009-07-30 09:55:57 -0700 (Thu, 30 Jul 2009)
      Log Message:
      • Reverted part of revision 4559 to get back compile time error
        checking for Binding tags.
      QE notes:
      Doc notes:
      Bugs: SDK-18802
      Reviewer: Pete F.
      Cycloner: Gaurav
      Tests run: checkintests
      Is noteworthy for integration: no
      Code-level description of changes:
        rep/MxmlDocument.java
          Added getAllBindingNamespaceDeclarations().
        rep/BindingExpression.java
        gen/ClassDefLib.vm
          Modified template to output *_bindingExprs() function if the
          document has Binding tags.
        ImplementationGenerator.java
          Modified generateBindingsSetup() to call
          generateBindingExprsFunction() if the document has Binding tags.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-18802
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
