0 Replies Latest reply on Jul 30, 2009 1:55 PM by jimmyoneshot
    Problems Displaying Images Within Installed AIR application
    jimmyoneshot Level 1
      I thought I'd already managed to fix this problem but it doesn't seem to be the case. I have two tilelists that items can be dragged between and when each item is clicked the information and"largeImage" contained within it should display in the right hand panel however this works fine in previewing but when I actually change it into an air application and run it the images do not display in the right hand panel when each item within the tilelists is clicked.
      What changes would I need to make to this code to make it work correctly when changed into an AIR app?
      <mx:WindowedApplication
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="initprofile1NewsAndSportSO()"
      <mx:Script>
      <![CDATA[
      Bindable
      Embed(source="assets/images/bbcnews_small.png"
      public var
      image1:Class;
      Bindable
      Embed(source="assets/images/itv_small.png"
      public var
      image2:Class;
      Bindable
      Embed(source="assets/images/skynews_small.png"
      public var
      image3:Class;
      </mx:Script>
      <mx:Script>
      <![CDATA[
      import
      mx.collections.*;
      import
      flash.net.SharedObject;
      public var
      profile1NewsAndSportSO:SharedObject;
      private var profile1NewsAndSportaddLinksFullAC:ArrayCollection = new
      ArrayCollection([
      {link:
      "www.bbcnews.com", label:"BBC News", icon:"image1", largeImage:"assets/images/bbcnews_small.png", title:"BBC News", description:"BBC News description will go here"
      {link:
      "www.itv.com/", label:"ITV", icon:"image2", largeImage:"assets/images/itv_small.png", title:"ITV", description:"ITV Description will go here"
      {link:
      "www.skynews.com", label:"Sky News", icon:"image3", largeImage:"assets/images/skynews_small.png", title:"Sky News", description:"Sky News Description will go here"
      private var profile1NewsAndSportaddLinksAC:ArrayCollection = new
      ArrayCollection([
      {link:
      {link:
      {link:
      private function profile1NewsAndSportReset():void
      new
      ArrayCollection([]);
      private function resetprofile1NewsAndSportAC():void
      for each(var obj:Object in
      profile1NewsAndSportaddLinksFullAC){
      private function initprofile1NewsAndSportSO():void
      profile1NewsAndSportSO = SharedObject.getLocal(
      "profile1NewsAndSport"
      if
      (profile1NewsAndSportSO.size > 0){
      if
      (profile1NewsAndSportSO.data.profile1NewsAndSportaddList){
      if(profile1NewsAndSportSO.data.profile1NewsAndSportaddList != "empty"
      var profile1NewsAndSportaddList:Array = profile1NewsAndSportSO.data.profile1NewsAndSportaddList.split(","
      var profile1NewsAndSporttempAC1:ArrayCollection = new
      ArrayCollection();
      for each(var str:String in
      for each(var obj1:Object in
      profile1NewsAndSportaddLinksAC){
      if
      (str == obj1.label){
      continue
      if
      (profile1NewsAndSporttempAC1.length > 0){
      if
      (profile1NewsAndSportSO.data.profile1NewsAndSportchoiceList){
      var profile1NewsAndSportchoiceList:Array = profile1NewsAndSportSO.data.profile1NewsAndSportchoiceList.split(","
      var profile1NewsAndSporttempAC2:ArrayCollection = new
      ArrayCollection();
      for each(var str2:String in
      for each(var obj2:Object in
      if
      (str2 == obj2.label){
      continue
      if
      (profile1NewsAndSporttempAC2.length > 0){
      else
      private function saveprofile1NewsAndSport(event:MouseEvent):void
      var profile1NewsAndSportaddList:String = ""
      if
      (profile1NewsAndSportAddLinksTilelist.dataProvider){
      if
      (ArrayCollection(profile1NewsAndSportAddLinksTilelist.dataProvider).length > 0){
      else
      profile1NewsAndSportaddList =
      "empty"
      var profile1NewsAndSportchoiceList:String = ""
      </mx:Script>
      <mx:TileList id="profile1NewsAndSportAddLinksTilelist" fontWeight="bold" dragEnabled="true" dragMoveEnabled="true" dropEnabled="true" height="292" width="650" left="21" columnCount="5" rowHeight="145" columnWidth="125" itemClick="titleLabel.text=profile1NewsAndSportAddLinksTilelist.selectedItem.ti tle; websiteLinkLabel.text=profile1NewsAndSportAddLinksTilelist.selectedItem.link; descLabel.text=profile1NewsAndSportAddLinksTilelist.selectedItem.description; linkImage.source=profile1NewsAndSportAddLinksTilelist.selectedItem.largeImage;" itemDoubleClick="{navigateToURL(new URLRequest('http://' + profile1NewsAndSportAddLinksTilelist.selectedItem.link))}" doubleClickEnabled="true" backgroundColor="#000000" borderColor="#FFFFFF" color="#FFFFFF" borderSides="top right left" y="25"/>
      <mx:Canvas id="SitePreviewArea" y="10" width="453" height="540" backgroundColor="#545050" cornerRadius="20" borderStyle="solid" x="692" borderThickness="2" dropShadowEnabled="true" borderColor="#000000"
      <mx:Label x="45" y="309" text="Website Name:" width="150" height="52" fontSize="14" fontWeight="bold" color="#FFFFFF" left="10"/>
      <mx:Label x="150.5" y="309" id="titleLabel" width="282.5" height="24" fontWeight="bold" fontSize="14" color="#FCFF00"
      <mx:Label x="124.5" y="385" text="Website Description:" width="200" height="24" fontSize="14" fontWeight="bold" color="#FFFFFF" textAlign="center"/>
      <mx:TextArea x="16" y="417" id="descLabel" width="421" height="69" textAlign="left" color="#FCFF00" borderThickness="0" backgroundColor="#545050" editable="false" enabled="true" disabledColor="#FFFFFF" backgroundDisabledColor="#545050" fontWeight="bold" fontSize="12"
      <mx:Label x="61" y="342" text="Website Link:" width="150" height="52" fontSize="14" fontWeight="bold" color="#FFFFFF" left="10"
      <mx:TextArea x="150.5" y="343" id="websiteLinkLabel" width="282.5" height="33" fontWeight="bold" fontSize="12" color="#FCFF00" borderThickness="0" backgroundColor="#545050" editable="false" enabled="true" disabledColor="#FCFF00" backgroundDisabledColor="#545050"
      <mx:Button id="goToSiteButton" top="494" left="168" label="VISIT SITE" fontWeight="bold" fontSize="14" color="#000000" click="{navigateToURL(new URLRequest('http://' + websiteLinkLabel.text))}" fillAlphas="[1.0, 1.0]" fillColors="[#FFFFFF, #DCDCDC]" borderColor="#000000"
      <mx:Canvas x="99.5" y="51" width="250" height="250" backgroundColor="#FFFFFF"
      <mx:Image id="linkImage" click="{navigateToURL(new URLRequest('http://' + websiteLinkLabel.text))}" width="250" height="250" x="0" y="0" scaleContent="true" top="2" right="2" left="2" bottom="2"
      </mx:Canvas>
      </mx:Canvas>
      <mx:TileList id="profile1NewsAndSportLinkChoice" fontWeight="bold" dragEnabled="true" dragMoveEnabled="true" dropEnabled="true" height="292" width="650" left="21" columnCount="5" rowHeight="145" columnWidth="125" itemClick="titleLabel.text=profile1NewsAndSportLinkChoice.selectedItem.title; websiteLinkLabel.text=profile1NewsAndSportLinkChoice.selectedItem.link; descLabel.text=profile1NewsAndSportLinkChoice.selectedItem.description; linkImage.source=profile1NewsAndSportLinkChoice.selectedItem.largeImage;" itemDoubleClick="{navigateToURL(new URLRequest('http://' + profile1NewsAndSportLinkChoice.selectedItem.link))}" doubleClickEnabled="true" backgroundColor="#000000" borderColor="#FFFFFF" color="#FFFFFF" borderSides="top right left" y="325"
      </mx:WindowedApplication>
      profile1NewsAndSportSO.data.profile1NewsAndSportchoiceList = profile1NewsAndSportchoiceList;
      profile1NewsAndSportSO.flush();
      profile1NewsAndSportLinkChoice.dataProvider){
      profile1NewsAndSportchoiceList += obj2.label +
      profile1NewsAndSportSO.data.profile1NewsAndSportaddList = profile1NewsAndSportaddList;
      profile1NewsAndSportaddList += obj1.label +
      profile1NewsAndSportReset();
      profile1NewsAndSportLinkChoice.dataProvider = profile1NewsAndSporttempAC2;
      profile1NewsAndSporttempAC2.addItem(obj2);
      profile1NewsAndSportAddLinksTilelist.dataProvider = profile1NewsAndSporttempAC1;
      profile1NewsAndSporttempAC1.addItem(obj1);
      profile1NewsAndSportaddLinksAC.addItem(obj);
      profile1NewsAndSportaddLinksAC.removeAll();
      resetprofile1NewsAndSportAC();
      = profile1NewsAndSportaddLinksAC;
