2 Replies Latest reply on Aug 1, 2009 7:28 PM by kevnug
    Help with AND/OR Search
    kevnug
      Hi all,
      I'm setting up an 'Advanced Search' feature using a filter function and need some help with the logic - seem to be suffering a brain fade...
      There's a search form with (let's say) 4 different options:  Name, Description, Price, Features.
      I want the user to be able to fill in all or none of the fields and return the matching results.
      I can do an OR function like this:
      if(Name.match(regx1) || Description.match(regx2) || Price .match(regx3) )|| Features .match(regx4){
           return true;
      }else{
           return false;
      I know I could change the "||" to "&&" - but I need to do this only if there's something to search...
      The only way I can think of doing this at the moment is to write a bunch of 'if statements' with all permutations - eg:
      if(Name && !Description && !Price && !Features){
           //match Name only
      }else if(Name && Description && !Price && !Features){
           //match Name & Description
      }else... you get the idea
      Thanks for your help!
      Cheers
        • 1. Re: Help with AND/OR Search
          Madhav Subedi Level 4
          it woud depend entirely on your application requirement; whether one field match is enough ( the second case ) or needs all fields match.
          i faced a similar case, in which, i had to AND ( as in the first case ) all the criteria whose search term is not empty.
          var criteria:Boolean = true;
          if( name not empty )
               criteria &= if(name.match)
          if ( price not empty )
               criteria &= if(price.match)
          hope it helps.
          • 2. Re: Help with AND/OR Search
            kevnug Level 1
            hey Madhav,
            Thanks for the pointer.  I haven't used a bitwise AND Assignment before...
            When I write some code like below I get a compile error saying "Implicit conversion of type Boolean to an unrelated type Integer"
            From what I understand, 'criteria' should remain true only if the comparator is true.  But why do I get a compile error?
            Do you know what I'm doing wrong?
            var nameMatch:Boolean = false;
            if(name){
                 if(name.match){
                      nameMatch = true;
            if(name){
                crieteria &= nameMatch;  // compile error here
            thanks for your help!
