I tried to do this by unsing both DW behaviors at the same time (form action = upload script, then added insert behavior) but it did not work. It inserted the record, but it did not upload the file. (Also, I wanted the file field to be inserted into one of the columns and that didn't happen, though the other form fields did)...
So since this apparently can't be done the "easy way," I'm hoping someone can show me how to stack this code to make it do both.
I assume u are using PHP. You can look for upload coding HERE. That code is actually for image but u just need to change it to accept file with the respective format as u need.
