3 Replies Latest reply on Jul 31, 2009 4:25 AM by Mylenium
    Cannot change CMYK colour of vector
      I have a AI file previously done in cs2 and I am now working on it in cs4. The file contains a vector drawing all consisting of the same colour, But when I change the colour of the vector and than click save the colour changes back to the original colour.
      please help
        • 1. Re: Cannot change CMYK colour of vector
          Wade_Zimmerman Level 6
          What you probably want to do anyway is do a save as not a save.
          I personally do not think it is a smart approach to do a save on top of opening a legacy file, IMO.
          Doing a save as does two things to your advantage one it will probably make the file size a bit smaller and two it i=will overwrite some of the out of date
          data in the file and you will always have the original.
          Try doing a save as.
          • 2. Re: Cannot change CMYK colour of vector
            Have you changed your Document colour mode to CMYK first ?
            • 3. Re: Cannot change CMYK colour of vector
              As Wade said, use a Save As.... The issue is either due to the original file being locked in some strange way, either on the file system level or in its internal data structure, or you requiring to indeed adjust a few document options to make it compliant with CS4. Fil's guess about the document color mode is a good place to start and you may need to checkk additional options for richt blacks and color profile conversions...
