5 Replies Latest reply: Jul 31, 2009 4:02 PM by Ramón G Castañeda RSS
    After CS4 install, how to remove CS3?
    robains Community Member
      I've successfully install my CS4 Extended upgrade, is it safe to remove CS3?  If so, how do I go about doing that?
      Thanks, Rob.
        • 1. Re: After CS4 install, how to remove CS3?
          Ramón G Castañeda Community Member
          No!
          If you want to uninstall CS3 (you don't have to), what you need to do now is, first, uninstall CS4 by using the Adobe Uninstaller.
          Then uninstall CS3, also using its own uninstaller.
          Then Repair Permissions with Apple's Disk Utility.
          Then install CS4 again, and Repair Permissions again.
          Note that you cannot just trash the application folders like we could with CS2 and earlier versions.  Beginning with CS3, an uninstall utility gets installed in Applications/Utilities/Adobe/…
          If you just try to uninstall CS3, your CS4 install will be damaged.
          As for Repairing Permissions, see next post.
          I have all versions of Photoshop since 7.0.1 happily coexisting on my system.
          • 2. Re: After CS4 install, how to remove CS3?
            I still advocate Repairing Permissions (with Apple's Disk Utility) before AND after any system update or upgrade, as well as before AND after installing any software that requires an installer that asks for your password.
            I have seen software installations go sour because the installer did not find everything as and where it should be.  I have also seen software installations go bad because the installer did not clean up after itself properly and did not leave everything as and where it should be.  This is just my own personal opinion and practice based on my own observations.
            Others may disagree and that's OK. I can only base my routines and my advice to others on my own experience and conclusion. I don't pretend to know why others believe otherwise.  Note that this suggestion begins with "I still advocate…", not "Apple recommends…".
            Repairing Permissions after the fact (i. e. not immediately before and after an install) may NOT help.  Try it anyway, though.
            Additionally,  if your machine does not run 24/7 so that it runs the daily, weekly and monthly Cron Scripts in the middle of the night as intended by Apple, run Cocktail (shareware) as well.
            Cron Scripts are maintenance routines designed by Apple to run on a daily, weekly and monthly basis in the middle of the night.  If you don't run them, you WILL run into trouble, sooner rather than later.
            Here's an excerpt from the Apple tech doc http://docs.info.apple.com/article.html?artnum=107388  Mac OS X performs background maintenance tasks at certain times if the computer is not in sleep mode. If your computer is shut down or in sleep at the designated times, the maintenance does not occur. In that case, you may want or need to run these manually.
            Mac OS X periodically runs background tasks that, in part, remove system files that are no longer needed. This includes purging older information from log files or deleting certain temporary items. These tasks do not run if the computer is shut down or in sleep mode. If the tasks do not run, it is possible that certain log files (such as system.log) may become very large. Also, from:
            http://docs.info.apple.com/article.html?artnum=106978
            The disk activity generated by find is a normal part of file system maintenance, used for tasks such as removing invisible temporary files that are used by the system. It is scheduled to occur early in the morning at 03:15 everyday, 04:30 on Saturdays, and 05:30 on the first day of each month.
            NOTE: There have been comments to the effect that Apple "fixed" this in 10.4.2 and later versions of the OS, but I have not been able to verify this to my satisfaction.  The reference in the 10.4.2 release notes are far from explicit on this subject.    Other, more reliable reports indicate that this seems to have been fixed in the current version of Leopard.
            In any event, Repairing Permissions and/or running the Cron Scripts cannot hurt.
            If you have DiskWarrior, run it regularly too.  It can't hurt either, and it often improves stability and performance.
            • 3. Re: After CS4 install, how to remove CS3?
              Confused ... I have the CS4 Extended upgrade that looks for my CS3 install to validate -- so if I have to uninstall CS3 and CS4 then reinstall CS4 how will the upgrade version be able to verify anything (since CS3 is gone)?
              Rob.
              • 4. Re: After CS4 install, how to remove CS3?
                Community Member
                iou should keep CS3 until you have figured out how to use CS4
                • 5. Re: After CS4 install, how to remove CS3?
                  Rob,
                  Yes, you are confused.
                  All Adobe updates are FULL installers.  They do not need to find a prior version to install.  When they don't find an earlier version, they just prompt you for the old serial number as well as the new one.
