2 Replies Latest reply on Jul 31, 2009 12:41 AM by Adobe-InDesign CS4
    ID-CS4 -JS - - Can't find using Grep options - Reg.
    Adobe-InDesign CS4 Level 1
      Dear All,
        Here I have a doubt about the "Find / Change Grep" in InDesign CS4.
      I can find the "Force Line Break" using the Grep options : ([a-zA-Z]*)-\\n([a-zA-Z]*)]
      Some time this Grep is working, some time this is not working ...
      I don't know what I made the mistakes. Please let me know any one can suggest and modify the below coding.
      I supposed to close and re-open the InDesign CS4 and ExtendScript tool, then First time this Grep is working fine...
      So I confused this. Please any one can give me a solutions.
      //================= Coding ==================//
         var myDoc=  app.activeDocument;
             app.findChangeGrepOptions.includeFootnotes = false;
             app.findChangeGrepOptions.includeHiddenLayers = false;
             app.findChangeGrepOptions.includeLockedLayersForFind = false;
             app.findChangeGrepOptions.includeLockedStoriesForFind = false;
             app.findChangeGrepOptions.includeMasterPages = false;
             app.findGrepPreferences.findWhat = "([a-zA-Z]*)-\\n([a-zA-Z]*)";
               mySearch = app.findGrep();
               for(var myForce =0; myForce<mySearch.length; myForce++)
                app.select(mySearch[myForce]);
                var mySel = app.selection[0];
                 myConts = mySel.contents;
                app.findGrepPreferences = NothingEnum.nothing;
                 app.changeGrepPreferences = NothingEnum.nothing;
      //=============== End of the Coding ========================//
      Please any one can kindly help me....
      Thanks & Regards
      T.R.Harihara SudhaN
        • 1. Re: ID-CS4 -JS - - Can't find using Grep options - Reg.
          vaasu devi
          Your script is working fine for me in CS3. I don't think so, CS3 and CS4 has much difference in 'find/Change' scripting. If the document has hyphen (-) before the line break, it showing that occurrences. Try like this, place that findGrepPreferences and changeGrepPreferences Nothing after that for loop.
          vaasu
          • 2. Re: ID-CS4 -JS - - Can't find using Grep options - Reg.
            Dear Vaasu Devi,
              Many thanks for your reply...
            I found, where I mistaken....
            Here My Correct Code :
                                 myConts = mySearch[myForce].contents;
                                 $.writeln(myConts);
            app.select() is working fine, meanwhile, I get the selection of the contents. That time only its throw the Error message. So I used to divert, app.select and Select Value of Contents to pass the "myConts" variable then I will do the other funtions.... Now My this time I'm not getting the Errors...
            Thanks Once again
            Regards
            T.R.Harihara SudhaN
