4 Replies Latest reply on Nov 4, 2009 11:59 PM by ALJN
    Indesign CS3 Server crashes while running a script
    Hrishikesh.deodhar
            I have a javascript .jsx which reads an XML which has the image urls in it.. It places that in an INDD document and then exports them into a pdf file...
      There are 10 instances created for the InDesign server since it is run as a service.... The issue that i am facing here is that the INDD document is saved properly, but the export into a PDF hangs the thread and the service in turn...The XML is imported into a template .indt and then saved as an INDD which then exports the pdf...
      I get an error dump in the install folder which basically prints out the following
      Exception code: C0000005 ACCESS_VIOLATION
      Fault address:  08438956 01:00017956 D:\Program Files (x86)\Adobe\Adobe InDesign CS3 Server\Required\FONT MANAGER.RPLN
      Registers:
      EAX:0012DA38
      EBX:00000000
      ECX:C26CB8C8
      EDX:007FC534
      ESI:11CF37F0
      EDI:1212D328
      CS:EIP:0023:08438956
      SS:ESP:002B:0012DA04  EBP:00000002
      DS:002B  ES:002B  FS:0053  GS:002B
      Flags:00210206
      Call stack:
      Address   Frame     Logical addr  Module
      I have no clue about why it happens in this fashion... I have a similar script which runs absolutely fine and there is very minimal difference in the two....
