4 Replies Latest reply on Aug 28, 2009 2:14 AM by Bernd Alheit
    Force persistent layout / initial view
    JessicaLampe Level 1
      Hello @all,
      I can set the layout of a pdf document by the doc properties methods, f.e.:
      this.layout = "TwoColumnLeft";
      But after saving the active pdf document these settings are lost. :-/
      I need a way to make these settings persistent.
      Manuelly this works with the menu "File > Properties > ..."
      I think I have to use the app (and not doc) properties. But what is the correct way to define this persistent inital view of the pdf document by JavaScript?
      Best wishes
      Jessica
        • 1. Re: Force persistent layout / initial view
          MichaelN Level 3
          Hi Jessica,
          I had a similar problem recently. I wanted to make every document open to full page view, and save that setting into the file.
          The way I solved it was to create a script that inserts a document Javascript into the PDF.
          So, to solve your problem, try:
          this.addScript("woColumnLeft", "this.layout = "TwoColumnLeft";);
          • 2. Re: Force persistent layout / initial view
            MichaelN Level 3
            Hi Jessica,
            this.addScript("TwoColumnLeft", "this.layout = "TwoColumnLeft";);
            You could incorporate this into a batch sequence.
            I do not like batch sequences, so the way I did it was to create a button in the toolbar that does the following to a PDF when clicked:
            1. Inserts some metadata into the PDF (title, copyright, author, etc)
            2. Inserts the document Javascript
            this.addScript("Page", "this.zoomType = zoomtype.fitP;");
            3. Locks the document
            I hope this helps
            Michael
            • 3. Re: Force persistent layout / initial view
              Hi Michael,
              many, many thanks for your answer!
              You are right! If I create a script that inserts a document JavaScript into the PDF, than it works fine.
              But there is a problem:
              If the other user (who would read the pdf) have deactivated the option "Activate JavaScript at startup" in the preferences menu of Acrobat, than the script won't work.
              Yes I think also, that's the best way to create a toolbar button or a menu entry (that's my preference) to run the JavaScript (I don't like the batch sequences too).
              But it would be better for me, if there is a way without including a special JavaScript into the document, which is executed by the open process of the pdf document.
              Is there another solution without a document JavaScript?
              Regards,
              Jessi
              • 4. Re: Force persistent layout / initial view
                Bernd Alheit Adobe Community Professional & MVP
                You can set the initial view in a batch sequence.
