1 Reply Latest reply on Aug 1, 2009 12:15 AM by Nishant28
    Remote Object - not able to get the returned value from java method
    Shivakumar Nekar
           Hi ,
      I am developing one sample flex aplication that connects to the java code and displays the returned value from the
      java method in flex client. Here I am able to invoke the java method but not able to collect the returned value.
      lastResult is giving null .  I am able to see the sysout messages in server console.
      I am using flex 3.2 and blazeds server  and java 1.5
      Here is the code what I have written.
      <mx:WindowedApplication
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" backgroundColor="#FFFFFF" initialize="initApp()">
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.binding.utils.ChangeWatcher;
      import mx.rpc.events.ResultEvent;
      import mx.messaging.*;
      import mx.messaging.channels.*
      public function initApp():void {
           var cs:ChannelSet = new ChannelSet();
           var customChannel:Channel = new AMFChannel("my-amf", "http://localhost:8400/blazeds/messagebroker/amf");
           cs.addChannel(customChannel);
           remoteObj.channelSet = cs;
      public function writeToConsole():void {
           remoteObj.writeToConsole(
      "hello from Flash client");
           var returnedVal:String = remoteObj.setName().lastResult;
           Alert.show(returnedVal);
      //[Bindable]
      // private var returnedVal:String;
      </mx:Script>
      <mx:RemoteObject id="remoteObj" destination="sro" />
      <mx:Form width="437" height="281">
      <mx:FormItem>
      </mx:FormItem>
      <mx:Button label="Write To Server Console" click="writeToConsole()"/>
      </mx:Form>
      </mx:WindowedApplication>
      Java code
      public
           public SimpleRemoteObject(){
                super();
      class SimpleRemoteObject {
           public void writeToConsole(String msg) {
                System.
      out.println("SimpleRemoteObject.write: " + msg);
           public String setName(){
                System.
      out.println("Name changed in Java");
                return "Name changed in Java";
      And I have configured destination in  remote-config.xml
      <destination id="sro">
         <properties>
          <source>SimpleRemoteObject</source>
          <scope>application</scope>
         </properties>
        </destination>
      Please help me .
        • 1. Re: Remote Object - not able to get the returned value from java method
          Nishant28 Level 1
          You are not able to get the returned value because if you see the Remote object help you will realise you have to use result="resultfn()" and fault = "faultfn()"
          In this you define what you wish to do.
          More importantly in the remote object you need to define which method you wish to call using the method class like this
          <mx:RemoteObject id="remoteObj" destination="sro" result="r1" fault="f1"  >
               <Method name="javaMethodName" result="r2" fault="f2"/>
          <mx:RemoteObject>
          r2 is the function where you get the result back from java and can use it to send the alert.
