1. Re: Server URL when using RH Server 8 Areas
tuls.garg Jul 31, 2009 3:02 AM (in response to RoboColum(n))Hi Colum,
I think the URL should look something like this:
http://<server>:8080/robohelp/server?area=<area>&prj=<project name>
Regards
Tulika.
2. Re: Server URL when using RH Server 8 Areas
RoboColum(n) Jul 31, 2009 8:20 AM (in response to tuls.garg)Thanks for this helpful response Tulika but we are not quite there yet. We are protecting our server address with an external IP address that when it is used redirects the user to the server. So if we use:
http://<ipaddress>:8080/robohelp/server?area=<areaname>&prj=<projectname>
we are being redirected to
As you’ll see the path is appended with a considerably longer string but I have no idea where it gets this from. Can you shed any light on this?
Read the RoboColum(n).
3. Re: Server URL when using RH Server 8 Areas
tuls.garg Aug 2, 2009 9:30 PM (in response to RoboColum(n))Hi Colum,
That URL with a long string is coming from RoboHelp Server. It contains information about the project and window to be shown and some more information needed by RoboHelp server to display help project. But this url should launch your help project from RoboHelp server. Are you not able to view help porject using this URL?
Regards
Tulika.
4. Re: Server URL when using RH Server 8 Areas
RoboColum(n) Aug 3, 2009 1:52 AM (in response to tuls.garg)Hi Tulika.
Thanks for helping me. That URL works perfectly when we use it inside our firewall but fails as soon as you use it outside it. This makes me suspect that the Server is not at fault. I have put a call out to our IT guys to look at the firewall settings. I'll post back when I hear anything.
5. Re: Server URL when using RH Server 8 Areas
RoboColum(n) Aug 3, 2009 7:09 AM (in response to RoboColum(n))OK we have got the link working outside of our firewall now. Tulika the link did work as intended. The problem we had was related to the external IP address we are using timing out before it could redirect you to the RH server. Thanks a million for the help and reassurance that I wasn't going mad.
6. Re: Server URL when using RH Server 8 Areas
tuls.garg Aug 3, 2009 9:09 PM (in response to RoboColum(n))I guess I didn't do much here
But glad to know it's working for you now
Tulika.
7. Re: Server URL when using RH Server 8 Areas
RoboColum(n) Aug 4, 2009 2:01 AM (in response to tuls.garg)On the contrary Tulika. The path to use with Areas is a new one on me with RH Server 8 and you provided some very useful information. I may have more or less got the path right without you but I'd have guessed and even then been left in the dark as to the logic behind the extended URL. Thanks again.
