5 Replies Latest reply on Jul 31, 2009 9:22 AM by Gregory Lafrance
    [Flex] Create XML from component id of mxml
    Nikynik
      my english it's no very good!!!!
      it's possible to create a Xml automatically by the id of some Text Input of my mxml page?
      examble of XML:
      <document>
           <id>id_TextInput</id>
           <value>id_TextInput.text</value>
      </document>
        • 1. Re: [Flex] Create XML from component id of mxml
          Nikynik Level 1
          I have some textinput and i have the necessity to create this xml whith ALL TEXTINPUT
          • 2. Re: [Flex] Create XML from component id of mxml
            Gregory Lafrance Level 6
            The following code answers your question.
            If this post answers your question or helps, please mark it as such.
            <?xml version="1.0"?>
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
              creationComplete="init();">
              <mx:Script>
                <![CDATA[
                  private var myXML:XML = <root/>;
                  private function init():void{
                    for each(var obj:Object in this.getChildren()){
                      if(obj is TextInput){
                        var ti:TextInput = obj as TextInput;
                        var xml:XML = <document>
                          <id>{ti.id}</id>
                          <value>{ti.text}</value>
                        </document>;
                        myXML.appendChild(xml);
                    for each(var xmlObj:XML in myXML..document){
                      trace(xmlObj.toXMLString() + "\n**********");
              </mx:Script>
              <mx:Button label="Btn"/>
              <mx:TextInput id="txt1" text="Text1"/>
              <mx:TextInput id="txt2" text="Text2"/>
              <mx:TextInput id="txt3" text="Text3"/>
            </mx:Application>
            • 4. Re: [Flex] Create XML from component id of mxml
              Nikynik Level 1
              i have an other problem....
              my mxml is:
              <mx:Vbox>
                <mx:Panel>
                   <mx:combobox/>
                   <mx:TextInput/>
                 </mx:Panel>
              ...<mx:Panell>
                     <mx:TextInput/>
                 </mx:Panel>
              </mx:Panel>
              and so in this method I can't find TextInput...
              • 5. Re: [Flex] Create XML from component id of mxml
                Here you go, please mark this as the answer if it answers your question :
                  <mx:Script>
                    <![CDATA[
                      import mx.core.Container;
                        getTextInput(this);
                      private function getTextInput(obj:Object):void{
                        if(obj is Container){
                          for each(var child:Object in obj.getChildren()){
                            getTextInput(child);
                        }else{
                          checkObject(obj);
                      private function checkObject(object:Object):void{
                        if(object is TextInput){
                          var ti:TextInput = object as TextInput;
                            <id>{ti.id}</id>
                          </document>;
                  </mx:Script>
                  <mx:Panel>
                    <mx:Button label="PanelBtn"/>
                    <mx:TextInput id="pnltxt1" text="PanelText1"/>
                    <mx:TextInput id="pnltxt2" text="PanelText2"/>
                    <mx:TextInput id="pnltxt3" text="PanelText3"/>
                  </mx:Panel>
                </mx:Application>
