2 Replies Latest reply on Aug 4, 2009 2:23 AM by endryha
    Send message to particular client via messaging
    endryha
      I want to send message to particular user via messaging (consumer/producer).
      I have following code for this:
      public void sendMessageToClient(Object msgBody, String clientId) {
              MessageBroker.getMessageBroker(null).routeMessageToMessageClient(createMessage(msgBody), getMessageClient(clientId));
          private MessageClient getMessageClient(String clientId) {
              MessageBroker messageBroker = MessageBroker.getMessageBroker(null);
              Object serviceId = messageBroker.getDestinationService().get("informer");
              MessageService messageService = (MessageService) messageBroker.getServices().get(serviceId);
              MessageDestination messageDestination = (MessageDestination) messageService.getDestination("informer");
              MessageClient messageClient = messageDestination.getSubscriptionManager().getSubscriber(clientId);
              return messageClient;
          private AsyncMessage createMessage(Object msgBody) {
              AsyncMessage msg = new AsyncMessage();
              // msg.setClientId(UUIDUtils.createUUID(true));
              msg.setTimestamp(System.currentTimeMillis());
              msg.setMessageId(UUIDUtils.createUUID(true));
              msg.setDestination("informer");
              msg.setBody(msgBody);
              // msg.setHeader("sender", "From the server");
              return msg;
      and corresponding configurations in messaging-config.xml :
      <destination id="informer">
              <properties>
                  <network>
                      <session-timeout>0</session-timeout>
                  </network>
                  <server>
                      <max-cache-size>1000</max-cache-size>
                      <message-time-to-live>0</message-time-to-live>
                      <durable>false</durable>
                  </server>
              </properties>
              <channels>
                  <channel ref="channel-rtmp" />
                  <channel ref="channel-amf" />
                  <channel ref="channel-polling-amf" />
              </channels>
          </destination>
      but it throws NullPointerException at flex.messaging.MessageBroker.routeMessageToMessageClient(MessageBroker.java:1372)
      any suggestions?
        • 1. Re: Send message to particular client via messaging
          endryha Level 1
          I has understood wath's the reason of this exception. It's because i am tryin to send message to client via lcds messaging (consumer/producer) with simple flex client id and in practice ids for consumer is different and i am don't know where i can get this id. I can see it by messageDestination.getSubscriptionManager().getSubscriberIds() code, but i can't get consumer client id of current user. Can anybody help me?
          • 2. Re: Send message to particular client via messaging
            endryha Level 1
            I have resolved this issue. To send message to client consumer you can use following code
            <code>
                public void sendMessageToClient(Object msgBody, Object clientId) {
                    Set clientIds = new TreeSet();
                    clientIds.add(clientId);
                    sendMessageToClients(msgBody, clientIds);
                public void sendMessageToClients(Object msgBody, Set clientIds) {
                    log.debug("send message to clients [ids = " + clientIds + ", message = " + msgBody + "]");
                    Object serviceId = messageBroker.getDestinationService().get(MESSAGING_SERVICE_NAME);
                    MessageDestination messageDestination = (MessageDestination) messageService.getDestination(MESSAGING_SERVICE_NAME);
                    messageService.pushMessageToClients(clientIds, createMessage(msgBody), false);
                    msg.setClientId(SERVER_ID);
                    msg.setDestination(MESSAGING_SERVICE_NAME);
                    return msg;
            </code>
            where client id is consumer client id. If somebody have a questions email me endryha@gmail.com
