1 Reply Latest reply on Jul 31, 2009 8:54 AM by kglad
    Actionscript 2 and Flash Publish Settings
    mach6ix
      Hi Everyone,
      I have posted a couple questions as of late and received fantastic support from other members (Thanks K-Glad).
      I do have what I'm assuming to be a basic question however I cannot find an answer for it.
      I added some login script to a page as listed below.
      stop();
      eval("$version");
      appname="mikesapp"
      loadVariablesNum("http://bars.bevinco.com/mike/newlogin.php", 0, "POST");
      //This verifys the users status and forwards them to the portion of the website they are authorized to access. Frame 100 = Regional Access, Frame 200 = Franchise Access, Frame 300 = Employee Access and Frame 400 = Denied Access and Back Button
      this.onEnterFrame = function () {
          if(_root.checklog == 100){
              _root.gotoAndStop(5);
          if(_root.checklog == 200){
              _root.gotoAndStop(10);
          if(_root.checklog == 300){
              _root.gotoAndStop(15);
          if(_root.checklog == 999){
              _root.gotoAndStop(20);
      My Question
      When testing this movie, I found that it was not moving to the section of the flash file that is relative to their "authorization level". I.E. I manually had my PHP echo back to flash, advising that REGIONAL ACCESS was used therefore it should be move this user to FRAME 5 of the file.
      I found that it was staying stuck on the first frame and not moving beyond the 1st frame which I thought had something to do with the stop(); that is listed at the top of the actionscript.
      However, when I changed the FLASH PUBLISH settings from Flash Player 8 to Flash Player 6, it works flawlessly.
      I attempted to publish using Flash 7 however it appears FLASH 6 is as high as I can go without loosing it's functionality.
      I'm curious WHY and will this limit our users from using the site if they have a lower version of Flash installed on their CPU?
      I have attached the project FLA file and the PHP file, being used on the server to manually tell this file that a REGIONAL has signed in or someone with "100" level status.
      As always, thanks in advance to anyone that has taken the time to read this post.
      Cheers,
      Mike
        • 1. Re: Actionscript 2 and Flash Publish Settings
          checklog is a string (even though it looks like a number to you).  flash 6 allowed quite a bit more code sloppiness than later versions.  so, it's very common for users to find publishing for fp6 works, while publishing for fp's higher breaks their code.
          you should use:
              if(_root.checklog == "100"){
          delete this.onEnterFrame
              if(_root.checklog == "200"){
              if(_root.checklog == "300"){
              if(_root.checklog == "999"){
