5 Replies Latest reply on Jul 31, 2009 11:47 AM by Gregory Lafrance
    Release Build Issue
    Jake Lyman
      Hello!
      I'm stuck on something pertaining to my release build. It's not working. I know there could be a lot of reasons for this, most related to path dependencies within my code. In my troubleshooting, however, I've stumbled across an issue that I think is at the root of the problem. I'm hoping someone has a solution!
      Here it is:
      I'm using Flex Builder 3, and it's an AS3 project. Running the project is no problem. Works great from the bin-debug folder. As soon as I pull the files in the bin-debug folder into another folder, however, it no longer runs. I'm doing this in the most basic way possible. Here are the steps I'm taking:
      1. create a new folder at the same level as bin-debug. Calling it, creatively, bin-debug2.
      2. copying all the files in bin-debug and pasting them in bin-debug2.
      3. opening my browser and surfing to bin-debug/project.html - works perfect.
      4. opening my browser and surfing to bin-debug2/project.html - doesn't work.
      How is it possible for the exact same files not to work just because the parent folder has a different name?
      I believe answering this will solve my release build issues.
      Thanks!!
        • 1. Re: Release Build Issue
          Gregory Lafrance Level 6
          Try Project - Clean
          What exactly is NOT happening, so what is going wrong.
          If this post answers your question or helps, please mark it as such.
          • 2. Re: Release Build Issue
            Jake Lyman Level 1
            Hi Greg,
            Thank you for taking time to help me troubleshoot this.
            Running the bin-debug version of the projects main .html page in a browser works. Meaning, the page loads, I see the default background color I've set in the compiler, and the opening animation starts.
            Then I copy and paste all of the files in bin-debug to bin-debug2. Try running the exact same .html file. The page opens in the browser and I see the default background color I've set in the compiler. The opening animation never starts.
            Jake
            • 3. Re: Release Build Issue
              I think this is security issue.
              To run the app anywhere outside bin-debug, compile with -use-network=false.
              To run the app on the server, compile with -use-network=true.
              bin-debug is the development environment, so that compiler flag is not as important.
              • 4. Re: Release Build Issue
                Jake Lyman Level 1
                Wow. Thanks, Greg. You did it!!
                With every release build do you have to manually tell the compiler -use-network=true? When I was looking for a solution prior to coming here, all the explanations said was needed was to choose "Project/Export Release Build..." Or are there only specific instances when you need to set that flag to true or false?
                Thanks!
                • 5. Re: Release Build Issue
                  Many people use automated build scripts, so there the compiler options would be set, with -use-network=true, but in your development environment maybe it would be false or may not matter.
                  I think you typically would not have a release build with it set to false, cause then it would only work on the local machine and could not connect to the web.
