0 Replies Latest reply on Jul 31, 2009 10:55 AM by Jason Szeto
    [svn:fx-trunk] 8959: http://bugs.adobe.com/jira/browse/ SDK-22152 - Calling ensureIndexIsVisible() on Spark DropDownList is unpredictable if an item is selected
    Jason Szeto Level 3
      Revision: 8959
      Author:   jszeto@adobe.com
      Date:     2009-07-31 10:55:21 -0700 (Fri, 31 Jul 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-22152 - Calling ensureIndexIsVisible() on Spark DropDownList is unpredictable if an item is selected
      In this bug, the VScrollBar?\226?\128?\153s value starts off at 8960, is set to 220, and then set back to 8960 all before a layout pass is run.  This exposed a bug in Range where programmatically setting the value to  new value and then back to the original value resulted in the wrong value.
      The fix is to check for the value setter to compare the new value against ?\226?\128?\156value?\226?\128?\157 instead of ?\226?\128?\156_value?\226?\128?\157.
      QE notes: Add test to Range components
      Doc notes: None
      Bugs: SDK-22152
      Reviewer: Hans
      Tests run: NumericStepper, Slider, ScrollBar
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/Range.as
