0 Replies Latest reply on Jul 31, 2009 10:57 AM by Chet Haase
    [svn:fx-trunk] 8960: Fixes a bug with the Fade effect where it would sometimes RTE when adding in an item that was in the fade-to state .
    Chet Haase
      Revision: 8960
      Author:   chaase@adobe.com
      Date:     2009-07-31 10:57:31 -0700 (Fri, 31 Jul 2009)
      Log Message:
      Fixes a bug with the Fade effect where it would sometimes RTE when adding in an item that was in the fade-to state. This happened when there were other objects in the same parent container that were not in both states, causing the retained index value of the faded object to be beyond the allowable range of the container. In this situation, we simply add the faded object at the end of the parent's children instead of at a specific place in the middle.
      QE Notes: None
      Doc Notes: None
      Bugs: SDK-22492
      Reviewer: Jason
      API Change: No
      Is noteworthy for integration: No
      tests: checkintests mustella/spark/effects
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22492
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateInstance .as
