2 Replies Latest reply on Jul 31, 2009 1:27 PM by SiHoop
    Full screen mode
    SiHoop Level 1
      I'm trying to use use the code below to go full screen. Also, I've added to index.template.html
      <param name="allowFullScreen" value="true" />
      but the file will not go full screen unless I access the swf file directly.
      Can anyone point me in the rigth direction? Are there other changes that need to be added to the html page?
      Thanks for your time.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
          <mx:Script>
              <![CDATA[
              import flash.display.StageDisplayState;
              private function toggle():void{
                  if(fs.selected == true){
                      goFullScreen();
                  } else {
                      exitFullScreen();
              private function goFullScreen():void {
                     stage.displayState = StageDisplayState.FULL_SCREEN;
              private function exitFullScreen():void {
                     stage.displayState = StageDisplayState.NORMAL;
          </mx:Script>
          <mx:Panel width="100%" height="100%" title="Very Basic Full Screen Sample"
          layout="absolute">
          <mx:CheckBox label="Full Screen" id="fs" click="toggle()" horizontalCenter="0" verticalCenter="0"/>
          </mx:Panel>
      </mx:Application>
        • 1. Re: Full screen mode
          babo_ya Level 3
          You need to add the following line of code in the index.templete.html.
          "allowFullScreen", "true",
          as below.
          if ( hasProductInstall && !hasRequestedVersion ) {
          // DO NOT MODIFY THE FOLLOWING FOUR LINES
          // Location visited after installation is complete if installation is required
          var MMPlayerType = (isIE == true) ? "ActiveX" : "PlugIn";
          var MMredirectURL = window.location;
              document.title = document.title.slice(0, 47) + " - Flash Player Installation";
              var MMdoctitle = document.title;
          AC_FL_RunContent(
          "src", "playerProductInstall",
          "FlashVars", "MMredirectURL="+MMredirectURL+'&MMplayerType='+MMPlayerType+'&MMdoctitle='+MMdoctitle+"" ,
          "width", "${width}",
          "height", "${height}",
          "align", "middle",
          "id", "${application}",
          "quality", "high",
          "bgcolor", "${bgcolor}",
          "name", "${application}",
          "allowScriptAccess","sameDomain",
          "type", "application/x-shockwave-flash",
          "pluginspage", "http://www.adobe.com/go/getflashplayer"
          } else if (hasRequestedVersion) {
          // if we've detected an acceptable version
          // embed the Flash Content SWF when all tests are passed
          AC_FL_RunContent(
          "src", "${swf}",
          "align", "middle",
          "quality", "high",
          • 2. Re: Full screen mode
            SiHoop Level 1
            Thanks for your answer. For documentation purposes, I want to note that the full screen command:
            stage.displayState=StageDisplayState.FULL_SCREEN;
            must be activated by a user's action such as a click.
            I found one other change that I had to make to get full screen to work for me.
            Below are the 4 changes I had to make to index.template.html
            In each of 2 instances of AC_FL_RunContent insert (and be careful with the commas!)
            Under <object classid=... insert
            Under <embed src=... insert
            allowFullScreen="true"
